Page 7 of 12 FirstFirst 123456789101112 LastLast
Results 151 to 175 of 281
Thread: Airbag Control Module, Internal Error (F0, 240 errors). Finally found a fix!
  1. #151
    Mar 2020
    Portugal
    e39
    need help to reset
    immortal.portugal@gmail.com
  2. #152
    Alameda, Ca
    2001 530i
    Abel can you still reflash the module? I might have one that needs reflashing possibly Thanks and Be Safe Chris
  3. #153
    Feb 2021
    Valencia
    E39 530d
    Hola este problema con la centralita tengo yo con el fallo 0 y no me borra en mi e39, si me puedes ayudar Abel.Gracias
  4. #154
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Please use a translator:
    Hello this problem with the control unit I have with the fault 0 and it does not erase in my e39, if you can help me Abel , Gracias.
    https://www.deepl.com/translator
  5. #155
    Apr 2019
    Vancouver, BC, Canada
    2000 BMW 540i
    [QUOTE=jbourne99;30296724]
    I follow your guide to soldered the wires to my MRSZ3 65776900727.
    However, carprog was not able to read the eeprom.
    I checked the soldering and they are good.
    Did I miss something?
  6. #156
    Mar 2021
    New Zealand
    Bmw 540it
    hey Abel i have a couple of modules that need to be reset how can i get a hold of you to get them done?
    thanks james
  7. #157
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by 540Wgn View Post
    thanks james
    Is it that common in NZ? It's funny because a few months ago I did a few for a group of New Zealanders. It's up to you if you want to deal with the long shipping, but send me a private message on the forums and I'll try to help.
    For the E39 modules, it's been hit or miss. Sometimes the internal error came back after a while.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  8. #158
    May 2021
    Lusby, MD
    2000 BMW 328i Sedan
    EEPROM Tool?
    What tool do you use to read and write the eeprom? I am trying to reset the internal fault code on MRSZ2/12
  9. #159
    Apr 2008
    Boston
    99 M coupe, 04 X5 4.4, 87 M3
    Hi Abel. I think I need to have the control unit reprogrammed. Can you help out and what would next step be? Regards.
  10. #160
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by vkbos View Post
    Is this for the Z3M, or which car?
    What errors do you have currently, and how many instances of each? (context: looking for a root cause.. or else risk having to clear it out again)
    What part number, if known?
    You can PM me with that information
    -Abel
  11. #161
    Apr 2008
    Boston
    Yes, It is (Z3M). I can't PM you as I don't have many posts to allow me the PM capability yet. Is there another way?
  12. #162
    Jun 2021
    Georgia
    2000 Bmw 528i
    ACM Internal error on e39
    Do you still repair these airbag modules? I recently bought an e39 with a F0 failure and was hoping I could pay you to repair it rather than spend an excess amount of money on a new module. Also is there an easier, more direct way I can reach you if you’re able to repair it?
  13. #163
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by DaveSS528 View Post
    I cannot PM you as you are too new here.
    I generally don't recommend posting your email address publicly, but it seems it's the only way.
    For e39, I highly suggest looking at all the errors to determine if it was an external auxiliary item causing the internal error, and the timing of the error (such as after a battery disconnect/reconnect etc). The problem that caused the F0 error must be fixed, or else the error will come back after I do a clearing.
    For e39, it's pretty nice as there are many modules available used for a fraction of the cost of a new one.
    -Abel
  14. #164
    Aug 2021
    Austin Texas
    2002 Z3, 2000 Z3 M
    I am glad I found this thread. I could not clear the code with one of those B800 scanners and misinterpreted the F0 code as 0F. I got an INPA read and it seems like I have the dreaded 240 code on a 2000 BMW Z3 M. Is it easier to buy a used EPROM and send it for reprograming or to pull the existing unit and send it in. I am in Austin BTW. Do you sell the modules outright? Core charge etc.
  15. #165
    Jul 2004
    Houston, TX
    36 Cylinders
    I have no more spare modules and they're really hard to find.
    Find out if there are other errors in your module, and how many of each. This can give you a hint if any accessory item is triggering the internal fault. If the problem that caused it still persists, the internal error can come back.
    Post it here, or send a pm with your email, or something. I still do these when time allows.
    -Abel
  16. #166
    Sep 2015
    Chicago
    2000 Z3 M Coupe
    PM'd you. Thanks!
  17. #167
    Aug 2021
    Austin Texas
    2002 Z3, 2000 Z3 M
    So, I just purchased the car, and the light came on shortly after.
    Given that it is not likely that the seller cleared the 240 code, it may have been my bad luck or something I did triggered the code. I did remove the seats to clean them and turned the key when I was doing so, but the code memory shows two consistent faults.
    It seems I cannot post the image I took of the faults. Most were a single time, I assumed due to me turning the key with seats removed.
    (21) Ignition Circuit ZK1 - Driver belt Tensioner = 112 error frequency
    (2) Belt Lock Passenger = 256 error frequency
  18. #168
    Jul 2004
    Houston, TX
    36 Cylinders
    I saw the pic. (google drive doesn't work well with forums)
    There it is, 256 error frequency. In 8-bit data, 255 is the largest number that can be counted to. Fix the connectors on both seats: spray, clean, and reconnect them. And then your car would be a good candidate for clearing.
    -Abel
  19. #169
    Aug 2020
    Los Angeles
    2002 M Coupe
    Don't mean to hijack the thread, Abel, but quick question for you and the group.
    Have you ever seen a control module go bad (on the earlier 2.5 or later 3.5 modules for Z3's) without the internal F0 error present?
    I have a thread running on this forum where I described what is happening, but in short - the only error I have been getting is a side impact sensor error, but I have tried 4 modules in it now (including a brand new $300 one!) and the error (passenger side 84: side impact sensor) persists. When you switch the impact sensors the error switches sides (to driver side 81) which SCREAMS the sensor itself but again I have tried a bunch of these!
    I just wanted to see if it could possibly be the central module even though no error is given?!
    Thanks, and any advice would be welcome!!!
  20. #170
    Jul 2004
    Houston, TX
    36 Cylinders
    For it to localize exactly which side it's on suggests the module is not bad at all. I would check that you are using the correct generation of side impact sensors (they were different across production dates) and that their connectors correct.
    -Abel
  21. #171
    Aug 2021
    Austin Texas
    2002 Z3, 2000 Z3 M
    I cleaned the connections, but wondered if the cleaning may need to happen at the other end. Am I correct in assuming that Belt Lock refers to where the buckle snaps in? What about the Belt tensioner? Does that need to be cleaned elsewhere? Both errors say they are not current, but not sure if the 240 code locks the current state. I was wanting to get the codes cleared to see if any codes come up afterwards thereby showing the issue and isolating it. The fear of course is that it throws the 240 code again and locks it. Does that happen instantly or is it more likely that it locks if the issue is ignored?
  22. #172
    Jul 2004
    Houston, TX
    36 Cylinders
    It's worth inspecting all the connectors, even the ones closer to the accessory. For example, the tensioners do have another connector nearer to the tensioner itself that can easily have coffee or sodas spilled onto it.
    If they say not current, I believe it.
    The internal error does not allow a complete code clear, so all others will remain in there.
    If the original issue is ignored, it will lock up again, yes.
    -Abel
  23. #173
    Aug 2020
    Los Angeles
    2002 M Coupe
    Yeah I considered that they were mismatched, but these all end in “910 678” for the part number, are two prong, and have the MRSA4 label on them. I am out of good ideas I am now checking instrument cluster, grounds, even the battery safety terminal. It’s gonna be a good one something I have never seen!
    Does anyone have a control module from a Z3 laying around, that they would be willing to loan or sell? It’s a v3.5 part number 6910677 with the brown plastic plug?
    Thanks if anyone has any advice I am all ears!
  24. #174
    Aug 2021
    Austin Texas
    2002 Z3, 2000 Z3 M
    Thanks Abel. If I have understood everything correctly. I can send my module to have the software reset which will remove all error codes including #240.
    What do you charge for the reset?
  25. #175
    Aug 2021
    NE Indiana
    2003 BMW M3
    This is a great read through - similar issue for me, running into a bunch of shadow/non-active errors. If it's possible to clear it pulling from the car, I feel like I outta at least try it.
    I'm currently running into these errors
    https://imgur.com/a/1pbCVs7
  1. F/S AIRBAG CONTROL MODULE & SIDE BAGS MODULES FROM A 98 M3
    By Corra in forum Exterior Lighting & Body Parts
    Last Post: 09-06-2012, 03:14 AM
  2. thinking about sending airbag control module out
    By KUSA325is in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-08-2009, 08:17 AM
  3. Airbag control module
    By matt325ibmw in forum 8 Series (E31)
    Last Post: 06-20-2008, 03:55 PM
  4. F/s Airbag Control Module & Side Bags Modules From A 98 M3
    Last Post: 02-08-2008, 02:49 PM
  5. Airbag Control Module
    By havnfun328 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-29-2007, 02:37 PM
