Page 2 of 12 FirstFirst 1234567891011 ... LastLast
Results 26 to 50 of 281
Thread: Airbag Control Module, Internal Error (F0, 240 errors). Finally found a fix!
  1. #26
    Kent, Ohio
    1998 M Roadster
    Just read through this thread--wow 328 Power 04, what incredible work. You may not be a forensic electrical engineer, but you should be.
  2. #27
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Quote Originally Posted by Mr Bingley View Post
    I too am impressed, and as everybody knows, I'm hard to please
  3. #28
    Aug 2015
    Santa Barbara, CA
    '02 330i
    Airbag Light OFF!!
    Abel, my Airbag dash light is no longer ON!! I plugged in one of the modules you reset for me and the light is no longer glowing. Your work is historic! Thank you very much for figuring this out. I was thinking that I would have to replace the module with a fresh one for $1000! Let's hope that all of the other drivers with airbag lights on and only retail to consider see this thread. Best regards,
    Donald
  4. #29
    Jul 2004
    Houston, TX
    36 Cylinders
    Glad to hear it. Yes, there is a 5-10 second boot up time on 'virgin' error cleaned modules. I noticed it happening when testing on my desk. They start processing a bunch of data, and you can hear the processor and circuits working. It then starts the life counter after all the self-checks.
    Feel free to scan the module with INPA for anything. Code menu and Status menu should show you everything operating as it should.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  5. #30
    Jul 2004
    Houston, TX
    36 Cylinders
    Today I found out that the MRSZ3 v3.0 (superseding part; BMW part number 65776908896) can ALSO get the F0 internal fault errors.
    I managed to get one of those cleared and working normally as well.
    -Abel
  6. #31
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Think this one could be reset? my side impact sensor got wet and i think it locked this one up.
  7. #32
    Jul 2004
    Houston, TX
    36 Cylinders
    That one (Temic MRSZ4) should be simpler and possible to do through K-Line diag line, instead of direct microprocessor chip access.
    I haven't physically tried one of these, but my tools should do it.
    -Abel
  8. #33
    Jun 2016
    Odessa, TX
    2000 BMW Z3 2.8 Roadster
    These are the ones Abel uses for the MRSZ4.
  9. #34
    Apr 2017
    Thomson Ga
    2000 BMW Z3
    Other air bag modules
    Can other part number air bag modules be reprogramed to work in the Z3. When I look on ebay for z-3 air bag modules, all I see are other part number modules listed in the search,not the part numbers for z-3
  10. #35
    Apr 2017
    Thomson Ga
    2000 BMW Z3
    Another question
    Since my air bag module seems to be defective, before I spend $1000 for a new one, what should I check before installing it. I certainly don’t want to fry the new one?
  11. #36
    Jul 2004
    Houston, TX
    36 Cylinders
    Well what is the problem with your current one? Every Z3 airbag module that I have been sent so far worked after the microcontroller reprogramming directly on board.
    And no, other part numbers will not work. eBay's compatibility charts are wrong. It has to be a Z3 part number.
    I would be able to tell if it's faulty by connecting to it directly on my desk. Skipping all car harness (potential problems there) and talking to it directly.
    Also, I would ask around, as some users sent me multiple and have extras.
    -Abel
  12. #37
    Apr 2017
    Thomson Ga
    2000 BMW Z3
    Does not give any readout when connected to inpa on 20 pin connection, but i have dim air bag light on dash.
  13. #38
    Oct 2013
    Tennessee
    2000 M roadster
    ok... following with fascination...
    question: have a 2000 M roadster...
    I would like to purchase a module and have you sprinkle your magic dust on it as a back up...
    what should i look for....
    i see in another thread these references:
    BMW PN: 65778386192, (Temic MRSZ3, v2.5)
    BMW PN: 65776908896 (Temic MRSZ3, v3.0)
    i'm a tech idiot (among other things) so be patient and use small words..
    gladly pay you for your magic...
  14. #39
    Jul 2004
    Houston, TX
    36 Cylinders
    Those are the correct part numbers, yes.
    If you do find one of those modules used with an "Internal Error" or "Crash Data Stored" then I can get those cleared. Otherwise it wouldn't need my fix, they will work (almost) plug and play.
    -Abel
  15. #40
    Jun 2016
    Odessa, TX
    Don't do it, I sent my module to Abel and when it came back I opened the box and had to fight 6 rattlesnakes, 15 tarantulas, and like 4 sun spiders to get the module out.
    (not really; the module came back nice and error-free. Abel's awesome. I recommend sending yours in for fixing).
  16. #41
    Lawrenceville, GA
    4 BMWs.
    I've still got my bricked v2.5. Might send it to you to virginize it.
  17. #42
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by LannVouivre View Post
    I put all the critters I can find in the backyard, what can I say.
    Quote Originally Posted by amancuso View Post
    Let me know, anytime.
    -Abel
  18. #43
    Oct 2013
    Tennessee
    2000 M roadster
    so either one will work correct? any others that would be suitable?
    (again, thank you for not making fun of me...
  19. #44
    Dec 2017
    Tarzana, California
    2000 BMW M Roadster
    Hi I just bought 2000 m roadster with a bad srs module, the prior owner sent me an uncoded module pn# 65778374799 after I purchased one from a 98 m roadster pn#65778374798 that is still good . If I connect the 98 module will that work and turn off the srs light. If not code you recode the one in the car and the uncoded one I'll give you the extra 98 module . How do you remove the srs control module ?
  20. #45
    Jul 2004
    Houston, TX
    36 Cylinders
    Both those part numbers are wrong for your car.
    -Abel
  21. #46
    Dec 2017
    Utah
    528i TA
    Hey Abel, I responded on my other post to you about my airbag light. Do I fall into this category of needing this done to mine?
  22. #47
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by cmfiero View Post
    Yes the E39 used the same type of airbag module, with the same exact issues with internal faults. So it needs the same kind of clearing as the Z3 module.
    -Abel
  23. #48
    Dec 2017
    Utah
    528i TA
    The mechanic that I had it at, used some snap on scanner and it said F0 internal ecu error
    05 ignition circuit ZK4>side airbag front left. Would this cause my intermittent no crank issues? I do know that the previous owner had someone replace window regulators... maybe something got disconnected?
    Tell me how I can get this to you if you think you can help me out and price etc..
    Thanks!
  24. #49
    Jul 2004
    Houston, TX
    36 Cylinders
    The airbag fault will not cause no crank.
    The F0 internal ecu error is the main problem and does not allow the airbag module to clear any codes or work properly.
    Send me a PM (private message) on here, and we can work something out. I suspect your intermittent no crank may be the EWS module or possibly crankshaft position sensor (if it hadn't been checked). I replied in your other thread.
    -Abel
  25. #50
    Boiling Springs, PA
    '02 Z3 3.0i 5 speed
    Abel, I opened INPA to see if I had the F0 code. I've read and cleared engine codes with it before, but where do I read codes related to this system? I noticed there was an airbag section and also a bunch of ABS sections.
    I have the intermittant airbag light, especially once the car is warm or the ambient temperature is hot.
  1. F/S AIRBAG CONTROL MODULE & SIDE BAGS MODULES FROM A 98 M3
    By Corra in forum Exterior Lighting & Body Parts
    Last Post: 09-06-2012, 03:14 AM
  2. thinking about sending airbag control module out
    By KUSA325is in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-08-2009, 08:17 AM
  3. Airbag control module
    By matt325ibmw in forum 8 Series (E31)
    Last Post: 06-20-2008, 03:55 PM
  4. F/s Airbag Control Module & Side Bags Modules From A 98 M3
    Last Post: 02-08-2008, 02:49 PM
  5. Airbag Control Module
    By havnfun328 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-29-2007, 02:37 PM
