Page 4 of 4 FirstFirst 1234
Results 76 to 79 of 79
Thread: Airbag Control Module, Internal Error (F0, 240 errors). Finally found a fix!
  1. #76
    May 2016
    melbourne ,australia
    2000 Z3 2.0 manual
    Just a follow up Thankyou to Abel and the forum. Module arrived back safe and sound in Australia and everything working fine again.
  2. #77
    Apr 2018
    Italia, Roma, Fregene
    bmw z3 roadster
    ITALIANO
    ciao, piacere mi chiamo Andrea - vivo a Roma -
    ho letto il post (attraverso il traslate di google)
    sono impressionato, complimenti
    ho letto che hai studiato in europa,
    vorrei poterti chiedere aiuto per questo ecu internal error
    parli italiano?
    oppure se hai voglia di supportarmi io traduco con il traduttore
    grazie a presto
    INGLESE
    hello, my name is Andrea - I live in Rome -
    I read the post (through the google translate)
    I'm impressed, congratulations
    I read that you studied in europe,
    I would like to ask you for help with this ecu internal error
    Do you speak italian?
    or if you want to support me I translate with the translator
    thanks, see you soon
  3. #78
    Apr 2018
    bmw z3 roadster
    I try to tell what happened:
    I replaced the original seats with m-series seats (English seats)
    from my originals I removed the 2 cables of the pretensioners and the wiring of the motors (forward / backward - up / down) since the connectors on the carpet of my car were different
    just mounted I do not seem to have turned on the light immediately, if I remember correctly I used the machine a few days ... it could have taken the timeframe to recognize that there was something wrong?
    subsequently to assemble the belt rebates I disassembled another time, together with the steering wheel to make it settle
    (restoring my old seat again, but without electrically attacking it) ... light on ... I thought it was normal and that when I reassembled the seats I could reset the warning light
    about a month later I reassembled the seats and from the diagnosis the discovery that along with 6 errors (with the words "not present at the moment") I also found the 240 ecu internal error - now I can not reset any errors
    can I have compromised the control unit in any way?
    that the seats in the m series have different resistances and therefore not compatible with my car?
    in your opinion is it a viable way to completely replace the wiring in the "old" seats and see if the error disappears?
    I'm afraid that even buying a control unit can recompress it in some way
    thanks for any advice you can give me
  4. #79
    May 2016
    2000 Z3 2.0 manual
    Hi all,
    I'm having a little trouble confirming through the forum threads if there is a drop-in replacement module for the seemingly unstable 65778386192. Is there another part number that could be expected to work in a compatible fashion with the rest of the SRS components? My module's 240 error has returned, so I suspect that its worth sourcing another one, rather than resetting it again. I was thinking that an updated part number would be a better idea, assuming the rest of the system is compatible with it.
    Can anyone advise?
    RealOEM suggests the following:-
    65776908896(03/01/2000 — ) , Exchangeable retrospectively65776910677(08/20/2001 — 08/13/2002) , nonexchangeable retrospectively65776922954(02/25/2002 — ) , Exchangeable retrospectively
    Can I expect 896 and 954 to work as direct replacements for 192?
    Thanks everyone.
  1. F/S AIRBAG CONTROL MODULE & SIDE BAGS MODULES FROM A 98 M3
    By Corra in forum Exterior Lighting & Body Parts
    Last Post: 09-06-2012, 03:14 AM
  2. thinking about sending airbag control module out
    By KUSA325is in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-08-2009, 08:17 AM
  3. Airbag control module
    By matt325ibmw in forum 8 Series (E31)
    Last Post: 06-20-2008, 03:55 PM
  4. F/s Airbag Control Module & Side Bags Modules From A 98 M3
    Last Post: 02-08-2008, 02:49 PM
  5. Airbag Control Module
    By havnfun328 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-29-2007, 02:37 PM
