Page 6 of 12 FirstFirst 123456789101112 LastLast
Results 126 to 150 of 282
Thread: Airbag Control Module, Internal Error (F0, 240 errors). Finally found a fix!
  1. #126
    Feb 2020
    Melbourne, Australia
    1998 BMW 328i
    Year of manufacture 2000
  2. #127
    Nov 2012
    Parsippany, NJ
    2000 740IL
    hey 328 Power 04, sent you a Pm not sure if it actually sent since its not in my sent box
  3. #128
    Jul 2004
    Houston, TX
    36 Cylinders
    Got it twice. I'll be replying in email
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  4. #129
    Feb 2020
    1998 BMW 328i
    Need assistance
    I have since purchased a replacement module (same part number 6577 6900727 and have run the diagnostic scanner which now shows the following -
    F MRS: Head airbag rear right
    E MRS: Head airbag rear left
    I cannot clear these codes
    Any advise and/or assistance would be greatly appreciated.
  5. #130
    Feb 2020
    1998 BMW 328i
    Need assistance
    I have since purchased a replacement module (same part number 6577 6900727 and have run the diagnostic scanner which now shows the following -&nbsp;<br><br>F MRS: Head airbag rear right<br>E MRS: Head airbag rear left&nbsp;<br><br>I cannot clear these codes&nbsp;<br><br>Any advise and/or assistance would be greatly appreciated.&nbsp;&nbsp;<br>
    <br>
  6. #131
    Jul 2004
    Houston, TX
    36 Cylinders
    It seems your airbag module came from a car with rear head arbags. Yours probably isn't equipped with them. You would simply need to code the second hand module to your car.
    -Abel
  7. #132
    Feb 2020
    1998 BMW 328i
    Need assistance
    Thanks 328 Power 04, much appreciated.
    I have taken the vehicle to a BMW specialist who appears to be having issues performing the recode. Is this something that can be performed using a foxwell diagnostic tool?
  8. #133
    Jul 2004
    Houston, TX
    36 Cylinders
    No, the foxwell diag tool cannot do it.
    It can be done with the NCS Expert program, as part of the BMW Engineering pack of diagnostic software.
    I've posted one version of it here:
    https://www.bimmerforums.com/forum/s...xperimentation
    Using K+DCAN cable and possibly 20-pin port adapter as needed.
    -Abel
  9. #134
    Mar 2020
    Lithuania
    e38 740iL
    Hi,
    After bodywork got an airbag light on. INPA shows errors in all 4 door airbags (resistance too high), supply voltage error and 240 Internal ECU failure. INPA is unable to clear these errors. Module is TEMIC 65776900727 v3.0. What tools do I need to reset this module ? If I understand correctly I also need virgin data from same module ?
  10. #135
    Apr 2020
    New York
    E39 M5
    Hi 328
    I’m one of those e39 guys with the 240 internal failure codes on not one but two modules. Long story short I just want to get them cleared and wanted to know if your still in the business of doing that? I’m exhausted
  11. #136
    Jun 2020
    Germany
    V40
    Hi, i have read your first postings and it seemed like a lot of work to figure out the pins.
    Do you rewrite the 8-pin-eeprom-chip to clear the internal fault? Is it similar to a crash error?
    So clearing crash error and rewrite software is practically the same? Just rewrite the file on the eeprom and it works again?
    I have found out about a solution to read the eeprom-chip directly and there are also tools sold with clean bin-files.
    You would have to open the ecu and remove the chip and then use a eeprom-adapter and the right tool to backup the bin and then replace it with a clean one.
    Found a guy on ebay selling the software. It provides those airbag ECU:
    BMW
    Bmw - Bosch - 0 280 015 31 Bosch 31697742701V
    Bmw - Bosch - 65.77 6905491 Bosch 0 285 001 368
    Bmw - Bosch - 65.77 6912123 Bosch 0 285 001 440
    Bmw - Bosch - 65.77 6912755 Bosch 0 285 001 458
    Bmw - Bosch - 65.77 6915886 Bosch 0 285 001 430
    Bmw - Bosch - 65.77 6933238
    Bmw - Bosch - 65.77 6933242
    Bmw - Bosch - 65.77 6964607
    Bmw - Bosch - 65.77 9125224 Bosch 0 285 010 060
    Bmw - Bosch - 65.77 9166057 Bosch 0 285 010 066
    Bmw - Bosch - 65.77 9184432 Bosch 0 285 010 070
    Bmw - Siemens - 65.77 8353598 OKI811 Siemens 5WK4060
    Bmw - Temic - 65.77 3414990 - G9V4G04BE50 MRSZ4
    Bmw - Temic - 65.77 6900727
    Bmw - Temic - 65.77 6910677 - G6TK23AH54
    Bmw - Temic - 65.77 6919789 - G8T2G11BBCE0
    Bmw - Temic - 65.77 6919789 - G8T2G12ABH0
    Bmw - Temic - 65.77 6919789 - GAT2G10ACE0
    Bmw - Temic - 65.77 6941018
    Bmw - Temic - 65.77 8367035
    Bmw - Temic - 65.77 8372520
    Bmw - Temic - 65.77 8372521 - MRSZ2 12 - Version1
    Bmw - Temic - 65.77 8372521 - MRSZ2 12 - Version2
    Bmw - Temic - G3T0C01AS73
    Bmw - Temic - G4TOEO8AD7
    Could you work with this?
  12. #137
    Jul 2004
    Houston, TX
    36 Cylinders
    Most of these modules specifically have an accelerometer placed right over across the microcontroller, so removing it is not an option.
    As for the files, I don't like using another car's files, because there will be coding differences then, and it doesn't become plug and play anymore.
    -Abel
  13. #138
    Jun 2020
    uk
    1998 bmw z3 roadster
    I have just caught up with this, my airbag module is from a 2000 wide body z3, it has been checked out and is unreadable and something is loose inside it, so I bought a used replacement, which works but it's throwing up error codes for side airbags which I don't have. BMW say I cannot use an airbag module from an another z3, I need to buy a new one. Here are the details of the modules, original one first. MRSZ3/DIAG 6111/ NR:31838619201G, SE Nr 99B2740C0082Q. Used one is as follows. MRSZ3/DIAG 6111 NR:31838619201G, SE Nr 99B3010C0299F. I have been told that it's possible the used airbag module came out of a vehicle that had been involved in a crash. So what are my options please.
    Cheers
  14. #139
    Did you have the airbag module coded to your car?
    I installed a used ABS module onto my Z3 the other day, coded it to my car, works great. No more airbag light
    PRICE CUT on ALL FABRICS
  15. #140
    Jun 2020
    uk
    How do I get this done or who do I see?
    Cheers
  16. #141
    Jul 2004
    Houston, TX
    36 Cylinders
    It can be done by anyone that has NCS Expert program (part of BMW Standard Tools 'INPA' pack) and a K-DCAN cable with a 20-pin adapter.
    I put a pack up here for Z3 use, which will work for coding the used part.
    I have a .pdf document there that describes exactly how to code the airbag module.
    all you need is in the first post.
    instructions on how to code the airbag module is in section D, part 2.
    -Abel
  17. #142
    Jun 2016
    Odessa, TX
    2000 BMW Z3 2.8 Roadster
    Quote Originally Posted by spitfire100 View Post
    I think the module has a sort of switch inside--an inertia switch--which may make a sound when shaken. I can check with my damaged module when I get home. This is just in clarification to something sounding loose inside of the SRS control module, in case anyone else shakes theirs and hears something moving.
  18. #143
    Jul 2004
    Houston, TX
    36 Cylinders
    It's the accelerometer used to measure impact. They all should do that
    -Abel
  19. #144
    Nov 2013
    Bentonville Arkansas
    '89 325iC, '00 540i/6
    Hey, I’ve got a 2000 E39 540i with a V2.5 31690072701C MRS that I’ve been trying to figure out a power supply fault and internal error code on. I’ve replaced the ECU with two separate units and they persist on each one after clearing codes. I’ve heard about some issues with the wiring for the airbags on these causing shorts and issues with the module, could give me any direction? I’m really really trying to attain the impossible; no codes, no lights, no leaks.
  20. #145
    Mar 2012
    Richmond Hill,Canada
    Soon
    I have a 2000 bmw m5 with mrs3 airbag module with the internal code error I replaced it with another one,it solved it only to come back few weeks later .
    Any Help appreciated!
    Amine
  21. #146
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by LazerSquid View Post
    Quote Originally Posted by BMWM5V8 View Post
    Amine
    For both of these, the same applies:
    Can you get a read of all the present codes, and how many times they've been triggered (the frequency)?
    That may hint as to what may be triggering the internal fault, presuming that it's not an issue with the control module itself.
    -Abel
  22. #147
    Mar 2020
    Raleigh, NC
    2000 Z3 Coupe
    Hi 328,
    I tried sending a PM about my 2000 Coupe module with F0 code
  23. #148
    Sep 2020
    Seoul korea
    Bmw e36/7 z3
    Hi. I have temic v3.0 65776908896 module. Can this be solved by soldering to the same place as 2.5?
  24. #149
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by Jeon seong hwan View Post
    Correct, this is the same processor and mask
    -Abel
  25. #150
    Mar 2020
    Portugal
    e39
    328 Power 04
    Need heeelpppiingfg please.
    Send mp please.
  1. F/S AIRBAG CONTROL MODULE & SIDE BAGS MODULES FROM A 98 M3
    By Corra in forum Exterior Lighting & Body Parts
    Last Post: 09-06-2012, 03:14 AM
  2. thinking about sending airbag control module out
    By KUSA325is in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-08-2009, 08:17 AM
  3. Airbag control module
    By matt325ibmw in forum 8 Series (E31)
    Last Post: 06-20-2008, 03:55 PM
  4. F/s Airbag Control Module & Side Bags Modules From A 98 M3
    Last Post: 02-08-2008, 02:49 PM
  5. Airbag Control Module
    By havnfun328 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-29-2007, 02:37 PM
