Does anyone happen to know the correct location for mounting the horns? PO has got the whole front end of my '91 850 boogered up and I would like to make it right, so if anyone happens to have a pic, diagram or really good written description I would really appreciate it.
Mike Drives:
BMW's
E24 - 635CSiA - (1) 1985 (US)
E24 - 635CSi - (1) 1985 (EC)
E31 - 850iA - (1) 1991 (Black)
E31 - 850iA - (1) 1991 (Calypso Red)
E32 - 740iA - (1) 1994
E32 - 750iA - (1) 1990 (Not an "L") (EC German National)
E32 - 735iL - (2) 1990
E32 - 750iL - (1) 1990
E38 - 740iLA - (2) (1) 1997 & (1) 1998
E38 - 750iLA - (1) 1998
E38 - 740iA - (1) 2000 "Short Sport"
E39 - 528iA - (2) - 2000 & (1) 1997
Also:
2015 Ram 3500 Dually, Cumins 6.7, Std.Cab. Long box 4x4 (To haul all this junk when necessary)
2014 Dodge Dart Rallye (Daily Driver)
2007 Mercedes Benz CL600 (Brabus SV12S)
Mercedes Benz SL's - (1) (2002) & (1) 1999 500 - (1) 1999 600
1967 Buick Riviera (2)
I seen them removed from the lower original location pictured to up higher where the white arrows are pointing, They don't get damaged as easily and are quite loud in this area.
Thanks guys!
I had a feeling they were originally underneath that piece of sheet metal, but it does seem like a bad place. I'm liking the upper mounting location more.
Appreciate the help.
Mike Drives:
BMW's
Also:
Thanks guys!
The first thing to ground out is the spoiler, so if the horns are grounding you are in trouble.
...and if you do relocate them, That's the best time to update them as well.
Suggestions on updates?
Mike Drives:
BMW's
Also:
I have these on one car because I seen them on Wuffers car many years ago>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://www.autohausaz.com/pn/un6627400
I have these Hella's on another car part # HELLA 007424801 Twin Trumpet High/Low Tone Horn which sounds great in my opinion and are cheap and easy install found on ebay, Video of there sound on a Nissan.>>> https://www.youtube.com/watch?v=eewKVoSFkGs
https://www.ebay.com/sch/i.html?_fro...4801+&_sacat=0
And the horn air compressor on my car for those horns died so I replaced with (on TXGR8Whites recommendation) Wolo Bad Boy air horns that are still fine today and take up less space.
https://www.ebay.com/sch/i.html?_fro...+horn&_sacat=0
91 850 (Panzer), 2012 Mini Cooper Countryman (WifeMobile) www.wuffer.ca
You can slightly bend the brackets and use the middle bolt location of the power steering cooler to mount the horns. This keeps them out of sight in the kidney grills while providing optimal output. They are also protected from water inside the radiator covering.
Hella Supertones are available fairly cheap and provide plenty of noise with the stock wiring and relay.
What "thumbs up" really means
