Results 1 to 25 of 60
Thread: Fuel pump stuff - seems to be a lot of this going around lately
    Dec 2007
    orange, ca
    '91 e31
    Seems like a fair amount of "crank but doesn't start" going around these days. Before I start pulling stuff apart, just wanted to make sure I had the right bits sitting around ready to go back in - #8 and #2 on the diagram - yes? Anything else that is an "auto-replace" once I get everything out? (This assumes I don't need 2 new pumps!)
    Dec 2007
    orange, ca
    '91 e31
    And - this seems strange - everything I've read and seen shows 2 electrical connectors instead of 1 - is this something unique to early cars??
    May 2014
    Philadelphia, PA
    e31 e28 e53 e92
    that must be the drivers side which has a fuel level sender only (no pumps), so just 1 plug. the passenger side contains BOTH fuel pumps and a fuel level sender for that side of the sadle bag gas tank and it has 2 plugs, one for the pumps (has 3 wires) and one for the fuel level sender. you dont need the gasket or strainer until you determine your pulling out the pump in which case yes those would be the min i would change. while your at it on the top of thd pump there are 2 short fuel hoses and 4 clamps on the passenger side you should replace and 1 hose and 2 clamps on the drivers side. part 3 the rubber fuel pump mounts (passenger side) on my were reduced to rubble.. literally chunks at the bottom of the tank so i would order 4 of those as well if your pulling the pass side pumps out.
    unless that pic is from the passenger side of an 840 which i believe has only 1 fuel pump but i think it still would have 2 plugs no?
    Dec 2007
    orange, ca
    '91 e31
    thank you - thought I was going crazy! (Had just read a post that said "pull the left rear seat")
    Pretty sure I'm going to pull the pumps, even if just to make sure everything is clean + happy in there.
    Jun 2014
    Blue Springs MO
    M70 6sp. 540iT, 535is
    Quote Originally Posted by rockytt View Post
    well, if you open the door on the right and look at the rear seats, left one would need to come off
    Dec 2007
    orange, ca
    '91 e31
    That's why "port" and "starboard" come in handy!
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    Starboard side is your pumps. Yes, #8 & #2 are correct. #2 is for pumps on Starboard side. Unless something on the port side is leaking or the fuel gauge is otherwise messed up -leave it alone, do not take it out. Really nothing serviceable in that side and it is a pain to get it in correctly.
    Replacing the gasket (#8) on the starboard pump assembly is best accomplished by installing the gasket on the tank first, then sliding the plastic pump housing down into it. Use lubricant on the rubber to be facilitate this, a bit of motor oil works wonders. Try it dry, you'll find out why...
    Eventually, pretty much everyone has to deal with a leak back there. The fortunate ones just need to service the two hoses to the pumps from the metal pipes under the bulkhead... the less fortunate find the plastic pump housing fatigues and gas seeps through. If all you're really thinking is replace the screen for some sort of prophylactic measure, might not be the best idea... those screens stay clean unless the tank somehow gets really polluted - and if that is the case, the whole tank need to come out for a proper scrub...thats really not fun.
    Then again, if your pumps actually die, 'while youre in there' is a good time to replace the screen...but the factory replacement pump housing assembly comes with the screens anyway
    '91 850i 6sp (mint) (sold)
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    left/right hand side of car is from the driver's seat looking forward.
    Also many online shops have this note
    Dec 2007
    orange, ca
    '91 e31
    certainly understand left/right - but was a referencing a thread that stated:
    Fuel pump issues are common on cars that have been laid-up for a while. Remove the left hand rear seat base and remove the access panel in the floor. You will then get easy access to the pump connectors. Sending 12V directly to the pumps will get them running and you will hear this easily. The 2 pumps run independantly.
    so my comment was a bit of a joke - thanks though...
    Thanks for the tips, Cartoonz - been sitting for awhile and I'll be pulling the pumps just to see how bad things are in there. Fingers crossed that the tank doesn't have to come out
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    I plan to start on my project car, '91 model, in the next week or so and the first thing I want to do is to pull fuel pumps, drain, and clean tank. I sure would appreciate your help if you could identify the part numbers for the parts you are going to order; the gasket, rubber mounts, and screen.
    I have already ordered two Walbro GSS340 fuel pumps and kits to do the upgrade that Dragon850 wrote up in the DIY section.
    Thanks,
    JP
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by JDP530 View Post
    Thanks,
    JP
    I don't think you really need to clean the tank, if I am not mistaken walbro pump comes with a screen.
    Here is the rubber mount you will need 4 of them: https://www.fcpeuro.com/products/bmw...nt-16141180474
    In retrospect I should have also replaced these when I was in there but they were not in horrible shape.
    Make sure you use SUBMERSIBLE fuel line when you follow my DIY thread.
    Dec 2013
    San Antonio
    Thanks for the help, dragon850!
    I found the RealOEM.com site a few minutes ago and identified some of the parts I need. This site sure is a great resource! I have already started an order with fcpeuro.
    Do you have part numbers for the rubber hoses that you modified for fuel supply lines to and from the filters? Thanks,
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    For the standard unbent hoses I used Gates green shield 220PSI fuel hose, for the pre bent molded hoses check my thread here for info and part numbers, it will also save you about $80 bucks
    https://www.bimmerforums.com/forum/s...with-a-twist-)
    Dec 2007
    orange, ca
    '91 e31
    also a thanks - will be taking a peek in there on Monday to see what's up - fingers crossed!
    Dec 2013
    San Antonio
    Quote Originally Posted by dragon850 View Post
    Thanks!
    Can the Gates green shield hose be used for submersible lines? Found Gates 27093 8mm/5/16"
    Gates 27340 for fuel injection line 8mm/516"
    I may have to spend the day reading through a lot of threads to become familiar with all systems and maintenance procedures.
    Sunny Cali,
    6.5 second 69 Camaro
    The readings are recommended and will save you plenty, They will also transform you into helpful in the read area's,)
    Dec 2013
    San Antonio
    I worked on my car this afternoon, cleaning and prepping battery tray for paint, removing rear side panels, and rear seats to access the tank ports. Looks like someone has been in to fuel pumps before since hose has the cheaper type of clamps. Also looks like someone has made a splice for pump wiring. And, the female pins to pump plug seem loose. I plan to do the Walbro upgrade and I should have the parts needed including pumps, hose, installation kits with filter socks, new seals, etc.
    Tell me I can get my fingers or tools on all the hose clamps under bulkhead so that hose sections can be replaced!
    Sep 2008
    Santa Barbara
    Most common is to use a 1"-1 1/2" hole saw on the sheet metal above the offending joints, allowing permanent access. Locate it right and you can use a rubber body plug to fill the hole, or some use heavy aluminum tape over it.
    Yeah, I cringed at this idea at first too... but the alternative is far from fun or simple.
    Sunny Cali,
    Like this? If so, I found it easier to find the plug/grommet first and then drill the hole that size. I made the hole while the tank was low on fuel and released the fuel pressure before drilling the hole with fire extinguisher in reaching distance.)
    Dec 2013
    San Antonio
    Wow, I never would have considered drilling access holes but it sure would make the job much easier! How many access holes did you need at each port?
    Sunny Cali,
    Only one was needed for the pass 14 years.
    Sep 2008
    Santa Barbara
    Yes, just one well placed access hole covers both pipes
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Yep, someone has been in there...I wonder what you gonna find inside I also see some very minor gas leak next to the connector? If it is a connector leaking it has a small crack, it is still possible to seal it from the inside with Loctite plastic Epoxy : https://www.amazon.com/Loctite-Plast...=loctite+epoxy
    I would only worry about drilling holes if the line is leaking.
    You will absolutely need 4 of these guys, I reused my isolators once but that was pretty stupid as they were cracked and were shedding rubber into the tank, so i ordered new it was so worth it. Plus they were so freaking satisfying to pop in! https://www.fcpeuro.com/products/bmw...nt-16141180474
    Another note on Walbro GSS 340, make sure you order from the same source as I linked in the DIY thread, I have nothing to do with the seller but I actually verified the pumps I received were genuine Walbro.
    There are alot of almost identical fakes floating around down to serial numbers and made in usa inscribed on the pump!
    Dec 2013
    San Antonio
    Thanks for noting the possible leak. I haven't started the car since I bought it and its been sitting a while. I want to go through most of the fuel system and secondary ignition to eliminate any potential problems before i try to run it. These are the Walbro pumps I received and they look like genuine Walbro pumps. Walbro could not verify that the pumps I have are theirs but he did say the number stamped below part number is the date-of-mfr.
    Is there suppose to be an electrical plug that fits onto fuel pump carrier? All I see are three female connectors and it looks like those have been spliced into harness. Can a plug be obtained anywhere?
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Can't tell 100% if it's real or not, take a pic of the top of the pump and the back plastic part of the electrical connector, there should be 4 digit part number engraved there.
    Could not find the fuel pump connector on real oem.
  1. I was greatful to be a part of this.
    By OUTLAW840ci in forum 8 Series (E31)
    Last Post: 09-18-2009, 08:49 AM
  2. Replies: 4
    Last Post: 04-24-2008, 01:37 PM
  3. This weekend is going to be a lot of fun...
    By Nemesis519 in forum Georgia sponsored by Harrison Motorsports
    Last Post: 01-15-2007, 10:58 PM
  4. Fan seems to be throwing lots of air...
    By dy540i in forum 1996 - 2003 (E39)
    Last Post: 09-16-2005, 02:27 PM
