BMW Enthusiast owned 1998 E36 328i Manual 5 speed 218k miles. I have owned this car since 2010 and for the last 7.5 years it's been my daily driver. Over that period of time I have put $6,000+ in parts alone. I have meticulously maintained this vehicle, I have made multiple upgrades (see list below) over the stock set up. Xpel Paint Protection on the glass headlights.
The car is not without issues including: airbag check light, reset tool included, and a small rust patch passenger doors (see photos).
There is a slight vibration at highway speeds I think it might be the center support bearing on the driveshaft. The Clutch bites well without any slippage. Occasionally the clutch engagement will be rougher than normal this is amplified since I removed the clutch delay valve for quicker shifts I believe the cause may be a hot-spot on the flywheel, this happens very infrequently I just want to be upfront about the cars condition. I would not hesitate to drive this car anywhere.
The quicker ratio limited slip differential and the suspension upgrades make this e36 very fun to drive.
VIN#: WBACD3326WAV23801
Rebuilt Alternator @218k
New Upgraded Group 49 battery @217k
Blower Motor and Resistor @196k
E90 rear view Mirror Homelink,Compass,Autodim
Bosch Euro Glass Headlights
Euro 3 spoke Steering Wheel
Bluetooth Handsfree Radio
Microsuede headliner
Coolant System overhaul
Thermostat, Water pump @217k
(Mz3 radiator,water pump,upper/lower radiator hoses,expansion tank return hose,radiator overflow,hose clamps,radiator mount) @202k
Engine Mounts,Transmission Mounts @174k
Valve Cover gasket @217k
H&R sport Springs,Bilstein sport shocks @177.
Front Control arms/strut mounts/CAB,Tie rods, UUC swaybars @188k
3.15 LSD ,Differential Mount,Subframe Bushings,Adjustable Rear lower control arms
Rear Trailing arm bushing limite,Alignment @188k
17" Style 96 Wheels 225/45/17 Michelin Pilot Sport AS3
Stock wheels included
Front Brakes @171k
Rear Parking Brake shoes @172k
https://photos.google.com/share/AF1Q...V1bk9zX3VjZG5n
Google photo link is currently broken - interested, would like to see all the pics. Thanks-
Sent from my LG-H811 using Tapatalk
bump
sold
