Results 1 to 25 of 41
Thread: Hard shifting
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Hard shifting
    Been having this issue since i purchased the car. I changed fluid and filter to the correct level but did not solve the issue. Other than possible worn tans mounts, is there a sensor associated with the transmission that could be causing this?
    Any help would be much appreciated
    May 2014
    Philadelphia, PA
    e31 e28 e53 e92
    assuming we are talking about a manual does it happen in EVERY gear? if it doesnt (only happens in low gears say 1st to 2nd) and it improves as the car gets warmer then you have worn syncros. to remedy needs a trans rebuild or let the car idle for 10 mins before you drive off every time.
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    The OP is more likely referring to a 4HP24 auto trans. Can try to drop the pan and clean the valves, but it isnt much fun and may not fix things. Obviously, check your mounts and guibos first. According to the guys that actually do remanufacture the 4HP24's still, do not use synthetic fluid either. Apparently, that can not only cause rough hard shifting but also is the most common cause of 4th gear going away completely.
    '91 850i 6sp (mint) (sold)
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Sorry, it's the 4hp24..minor detail.
    I'll inspect the guibo but doubt that's the issue. Thanks for the feeback.
    Del Mar, CA
    91 850i, 01 740i, 06 760
    Double check the fluid level. Its not that difficult to rebuild the valve body.
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Quote Originally Posted by BMSman View Post
    Thanks, I'll check past posts on the valve rebuild and see if it's a DIY project.
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Btw, is it not counterintuitive to have the trans fluid dipstick tip in black? Drives me crazy trying to figure out the level.
    May 2014
    Philadelphia, PA
    e31 e28 e53 e92
    Removed by mod team, no personal attacks
    Jul 2016
    Chicago, Illinois
    are slow
    The filtered solenoid on top of the VB, clean it.
    Del Mar, CA
    Quote Originally Posted by nrp22101 View Post
    Not really a DIY but this will give you an idea of what is involved
    http://www.km5tz.com/BMW%20850iP8.htm
    But as XAlt suggested, there is a gauze filter in one of the solenoids that sometimes gets clogged. I believe Shogun has a DIY on that somewhere.
    NY, NY
    84 633, 91 M5, 91 850
    Quote Originally Posted by XAlt View Post
    I'm planning to do this job soon. I read Shogun's DIY and it seems manageable.
    What fluid is best for the 4 speed? I am planning to use Redline D4.
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    You guys all rock. Much thx.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    valve body rebuild 4HP22/24 on my website http://twrite.org/shogunnew/files/ja...Valvebody.html
    Important is that you clean the metal screen in front of this solenoid valve http://e32b12.blogspot.jp/search/label/4HP24
    when you scroll down further, you see also that the ATF filter O-rings sometimes do not fit from cheapo aftermarket filters, pay attention to that, otherwise air can be sucked there with the ATF and the infamous whining of the trans starts
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Quote Originally Posted by shogun View Post
    Will do, thanks.
    May 2014
    Philadelphia, PA
    e31 e28 e53 e92
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Jan 2005
    Japan
    Gentlemen, calm down please, I assume no one wants to have a cool down period here.
    https://www.bimmerforums.com/forum/s...-Rules-and-FAQ
    *Here, Again, is Kevlar's Profanity Announcement:
    This is just a reminder... profanity is strongly frowned upon in our general forums.
    Our staff will be working to clean up any profanity found in thread titles as well as message content. Please consider that the use of profanity on the forum degrades the content nature of our forum for all and as such, we would like to have you be your own guide to curtail the profanity. We could put a censor filter in place to remove all profanity, but it would require removal of some of the features that the users like, so we are asking you to be your own guide and think before you post.
    Any user found to be using excessive unnecessary profanity will have their posting privledges suspended or revoked based on the situation.
    Jul 2014
    Westfield, IN
    '91 e31 M70
    To the OP... finding a rebuilt VB is getting more and more challenging. But I can tell you with Shogun's guide, it's actually a pretty easy DIY.
    '07 e65|N62 - Alpina B7 - Black Sapphire|Black|Loaded|GONE
    '02 e46|M54 - Orient Blue|Beige|'Vert|GONE
    '00 e39|M52 - Anthrazit Metallic|Grey|GONE
    '01 e38|M73 - Anthrazit Metallic|Schwarz|Shadow-Line|GONE
    '91 e31|M70 - Schwarz|Schwarz|M70|FOR SALE
    '13 328i Auto - Black Sapphire|Coral Red|Sport Line|GONE
    '05 545i SMG - Jet Black|Black|Bamboo Anthracite|GONE
    '07 335i Auto - Montego Blue|Grey|GONE
    '05 545i SMG - (Euro Delivery 7/22/05)|Black Sapphire|Auburn|GONE
    '97 528i Auto - GONE
    Jan 2005
    Japan
    Europeantransmission has a reman valve body for a 850, just in case you want to buy one http://europeantransmissionscom.x-sh...me.php?cat=696
    $315.00 BMW 4HP24 valve body from ZF
    ZF 4HP24 EH electronic, 850i,remanufactured and adjusted with firmer shift tested with computer simulator
    Del Mar, CA
    That's a great price but unfortunately it says 'out of stock'.
    Jan 2005
    Japan
    He can send his valve body to there for reman, no problem. I can also do that, but I am too far away and shipping is too costly and time consuming.
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Where's the best place to get the necessary parts to reman, including the filter O ring? I may give it a go. I'm sure it's harder than it looks but your instructions are terrific.
    Jan 2005
    Japan
    Ross1 had very good experience with Eriksson, even with small parts like orifices https://www.bimmerforums.com/forum/s...light=orifices
    he called them, told them the serial number of the trans, stuecklistennummer of the trans and they checked and shipped him the parts quickly http://zftranspart.com/
    http://www.zftranspart.com/index.php...parent=46&pg=1 looks like they also have reman valve bodies
    Filter kit with o-ring and pan gasket I bought from FCP EURO, they have the Meistersatz kits, made in Taiwan, have used already quite a number of them w/o any probs. Make sure you get the set with the filter with the long neck, there are kits for 4HP22 which almost look same, but the filters have the short neck for 4HP with shallow ATF pan like E30 etc.
    Or buy also from Eriksson, they also have kits
    In case you really want to disassemble the valve body, in any case you need the paper gasket between the plates of the valve body, on the 4HP22 and 4HP24 they are sticking to the plates and usually break when disassembling the VB.
    Part number is ZF 1043 328 080 for the 4HP24, and also probably new plastic balls. In case you are not in a hurry, disassemble and check what you need and then order what is required.
    That will be cheaper, because from the valve body repair kits like they are available for 5HP18 and 5HP30, most of the parts are not absolutely necessary, example http://www.zftranspart.com/index.php...d=52&parent=40
    There are no valve body kits available for 4HP, because too many changes and paper gaskets etc., must be ordered by serial number and stuecklistennummer.
    May 2014
    Philadelphia, PA
    e31 e28 e53 e92
    @shogun, my apologies. i just think its unfair to them that this thread was cleaned before i got to read their responses lesson learned, it wont happen again.
    Oct 2008
    Madrid - SPAIN
    850iA - 1990
    I had a similar issue and finally went the route of replacing the VB with one coming from a 750 E32 4HP24...( far cheaper than one from a 4HP24 from a 850 ). I cleaned it with brake cleaner, and bye-bye hard shifting.
    The original one is sitting at my garage waiting for me to find time to do some extensive cleaning...
    One photo from both Valve Bodies and a link to the post ( in spanish but plenty of photos )
    https://www.bmwfaq.org/threads/zf-4h...lvulas.812865/
  1. Hard Shifting into 1st gear
    By LouSierra///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-20-2004, 10:00 PM
  2. clutch would not disengage @ hard shifting
    By Matutino in forum 1992 - 1999 M3 (E36)
    Last Post: 02-01-2004, 03:20 PM
  3. Shift knob keeps coming off on hard shifts, any fix?
    By BGM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-07-2004, 04:32 PM
  4. slight lift in front on hard shifts
    By JT///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-01-2003, 06:33 PM
  5. Damn shift knob pops off under hard shifting!
    By Hugo in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-28-2002, 10:05 AM
