Results 1 to 4 of 4
Thread: 750Li xDrive 2013 injector replacement
    Austin, TX
    BMW 530i
    Cool 750Li xDrive 2013 injector replacement
    Hi All,
    I am planning to replace all my injectors in my 750Li xDrive 2013 as it has throw a "drive train malfunction" and cylinder 5 injector problem.
    There is a need for 2 things:
    1- A DIY for this procedure
    2- An INDY K+DCAN software and connector to update the injector codes in the computer
    Does any one by any chance know of a post or can help me in this process?
    I am also in the DFW area in Texas.
    Thank you,
    May 2017
    USA
    E90, E46
    This is not a DIY job.
    Austin, TX
    BMW 530i
    This gentleman has done it himself on his 3 series. My injectors are exactly the same, so I guess I should be able to DIY, if not at least worth the try.
    http://www.e90post.com/forums/showth...=fuel+injector
    BMW stealer wants $1,200 to replace just one injector on cylinder 5 and about $5,000 to replace all eight of them.
    May 2017
    USA
    E90, E46
    The injector replacement in an E90 and a F01 are completely and totally different. They use the same style injectors ( piezo ) but that's about it. It's not a DIY job seriously. If you insist on royally ruining your car then go for it. It's only nuts and bolts right?? Piece of cake...
  1. 2013 BMW 750Li xDrive
    By Adfundum in forum 2009+ (F01,F02,G11,G12)
    Last Post: 04-30-2017, 08:42 AM
  2. Purchasing a 2013 328i xDrive Coupe to Replace My Leased 2014 320i xDrive
    By kmac47 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 11-16-2016, 06:01 PM
  3. DIY Fuel Injector Replacement.
    By 7Serious in forum 1995 - 2001 (E38)
    Last Post: 06-14-2007, 02:39 PM
  4. Replies: 7
    Last Post: 02-12-2006, 03:18 PM
  5. Today's Tech Article - BMW Fuel Injector Replacement
    By Wayne@PelicanParts in forum 1991 - 1999 (E36)
    Last Post: 11-17-2003, 10:20 AM
