Anyone have a good description of where to find the terminating resistor for the PT-CAN bus? All i can find online is "passenger kick panel" which i have torn a part and cannot locate it. Car is a 2004 745IL
Current:
- 09 335i MSport, FBO.
- 98 Euro M3, Estoril Blue
- 04 M3, Carbon Black, 6 Speed Coupe
- 06 M5, Black on Black, Full Leather.
- 73 3.0CS, Tagia Green, 5 speed M30b35 converted
Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
Im still have troubles locating the front PT_CAN terminating resistor. Ive located the rear one under the back seat, but cannot locate the front one.
Current:
So to answer your question there is one under the rear seat and one in the right front kick panel.
why do you need to access the terminating resistors?
I found the front one today. its actually at the front of the car behind the bumper. Not sure why so many resources say its in the front right kickpanel..
This car was unable to communicate with the DSC and ARS modules. The front terminating resistor was shot. Replaced it today and restored communication.
For future reference U5 is the front terminating resistor for the PT-CAN bus
Where exactly is the rear 120 ohms resistor located at, I've removed the bottom rear seat cushion and I don't see it? I've only found the front one in front of the right side wheel behind the front bumper area.
I found the 120 ohm resistor below the right front headlight and it checked good. I sent my ABS computer out to Module Repair Pro in California for repair and they found a bad speed sensor and a bad barometric sensor but the module was communicating on the bench. Something is pulling the CAN Bus offline so I'm going to locate the rear terminating resistor and then the rotation rate sensor to see if they are good. If those check out it could be another module pulling the CAN line down or a broken wire.
I'll keep you all posted.
Cheers,
Poon
Does any body know the part number for the front PT can terminating resistor?
Hey I Dont know if your still online these days but do you remember where exactly to find the front one? Ive tried to find it based on the photos to No avail. Also how were you able to reach it? did you have to remove the wheel? Is it the same as on the 2003 as it is on the 2004?
