Results 1 to 7 of 7
Thread: Weird noise cannot find the source E46
    Aug 2017
    Lisbon
    318i e46 98'
    Hello there, i am new here, but not to the E46 DIY lol, been fixing the various problems that appear, so far so good but...
    So i have a very weird noise on cold start and after 1min or so it stops and if the car is warm it does not sound, and i cannot find the source, its not the SAP, not the power steering pump, i tried to listening to everything with a stick, might be a tensioner or something? I can upload a audio clip tomorrow, its really annoying me lol
    The car is a 98' e46 318i with 200 000km on the clock.
    Thanks to all.
    Dec 2013
    Chicagoland area
    EXOTICS
    The symptoms you describe points to secondary air pump,
    Pictured here:http://www.realoem.com/bmw/enUS/show...diagId=11_2193
    Aug 2017
    Lisbon
    318i e46 98'
    The secondary pump had a problem something ago, had a very bad noise so i cleaned the egr and it solved the noise apparently, but its not the SAP.
    Aug 2017
    Lisbon
    318i e46 98'
    So did some checking again in the SAP and the noise comes from the system, so i tried to disconnect the the plug or sensor to the SAP and a brown fluid come out! This is normal ?
    Dec 2013
    Chicagoland area
    EXOTICS
    RUST!
    Water formed by condensation runs down the hose and collects, pools at the pump.
    Remove the hose between the EGR valve and the pump, peer into the pump at the opening,
    you will probably see pooled, rusty, water. EGR failure caused the pump failure due to water.
    If the pump is replaced, don't ignore and forget to replace the EGR valve also.
    Aug 2017
    Lisbon
    318i e46 98'
    Disgusting stuff LOL, i disconnect the SAP for now, i need to replace all the system but to many things to do and no $$$ , for now its going to be disconnected, thanks for the help!
    Dec 2013
    Chicagoland area
    EXOTICS
    I understand the $$$ problem myself, sometimes. You should be fine with it disconnected ,until you are able to replace.
    It is an emissions system, hope you don't have strict emissions standards, testing in your area, Good Luck!
  1. 2000 323CI steering wheel shake....cannot find the source...
    By dhurley34 in forum 1999 - 2006 (E46)
    Last Post: 03-29-2017, 12:22 AM
  2. Suspension noise - cannot find source
    By YaSureYouBetcha in forum 1999 - 2006 (E46)
    Last Post: 09-19-2013, 04:00 PM
  3. Find the source: Loud screeching noise at high speed
    By SneakyMike in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-12-2013, 07:49 PM
  4. Help me find the source of a humming noise
    By noahabel in forum 1992 - 1999 M3 (E36)
    Last Post: 07-26-2007, 04:53 PM
  5. Another weird noise coming from the car
    By KnightRider/AMG in forum 1991 - 1999 (E36)
    Last Post: 02-04-2006, 12:39 PM
