Results 1 to 10 of 10
Thread: Spark Plug check
    Aug 2017
    Nevada
    1994 BMW 318i
    Spark Plug check
    So I took out my spark plugs to replace them today, does the condition of these say anything about my engine? Keep in mind I'm sure the past owner never replaced them.
    Jun 2010
    NY
    1997 328i
    Carbon fouling, your running rich. Smoke test the vacuum system for leaks. Replace the oxygen sensor.
    Aug 2017
    Nevada
    1994 BMW 318i
    Quote Originally Posted by Eric93se View Post
    I just replaced all the broken vacuum lines, thanks for letting me know it's running rich!
    Aug 2009
    sunnyvale CA
    325is
    Carbon coated = rich yes. But the oil on the plugs is a V cover seal leak but it also got into the cylinder on one and you were burning oil. or was the plug a bit looses? Plug tips look clean, they are not copper because it looks to uniform and pointy, Iridium? They can go for 100,000 miles. Not OEM in 94
    Aug 2017
    Nevada
    1994 BMW 318i
    Quote Originally Posted by gc325is View Post
    The plug was a bit loose but if you say it could be the seal I'll likely just replace the seal to be safe. They are iridium though and they probably have some life in them but I'm going to replace them just to be safe. Thanks for the information!
    Aug 2009
    sunnyvale CA
    325is
    Valve cover seal leak is also a vacuum leak. It is also the reason why the plugs are coated outside with oil.
    The one plug thats not all black means it was burning different than the rest. Hopefully it was a loose plus and oil seeped into the plug, not a internal oil seal on a valve or piston. As eric said your O2 sensor may not be working and the CAT could be dead. Cylinders may be filled with carbon too.
    You never said how the car was running. If you want to know how well the engine is there are other tests you can do. Cylinder compression test, oil inspection, and since you have 4 plugs a head gasket inspection and other specific 318 item.
    Jun 2010
    NY
    1997 328i
    I agree you should do the valve cover gasket, but it's not likely the cylinder was drawing in oil (to burn), it's just oil seeping by the valve cover gasket. Be sure to read any guides on how to properly do the valve cover gasket for your engine there maybe the need to put a few strategic dabs of silicon sealant. I forgot one time and it did leak right where it's supposed to get some RTV silicone.
    Dec 2014
    Stuttgart, Germany
    One Too Many
    No Just running Rich but also some oil burn and introduction of outside air going on, some plugs are grayish. Check for more leaks, grab a cheap $50 smoke party fog machine from ebay, great for finding leaks, likely the rocker cover leak..
    "So we've come to the conclusion that BMW just has parts laying around they decide to throw on cars for no reason."
    Interest on a Very Budget Supercharger Build??
    Wisconsin
    98 328IS 03 325xi
    Oil doesn't seep past the plugs into the cylinders unless they are half way out and the engine isn't running. Think about it, gravity vs 150+psi, which way is the oil going flow?
    Gave away my BMWs, driving a VW and an Audi now.
    Aug 2009
    sunnyvale CA
    325is
    However, A Hot engine that cools down has lots of pressure to suck in oil from a loose plug
    https://www.youtube.com/watch?v=Uy-SN5j1ogk
    I just pulled my Bosh iridiums. They look almost as bad as yours. Only ~25,000 miles. I was also reading a higher impedance on a few 11K ohms vs 5K. I am thinking the oil could be fouling them then causing the plugs to be damaged and cause a resistance change? Which then leads to a miss fire and poor emissions.
    Or I'm just running rich because that VC is leaking again
    PS: SMOG guy said oil burning is the biggest cause for a dead CAT.
  1. spark plugs checked, holy cow, pic's
    By das Boot in forum Forced Induction
    Last Post: 08-31-2010, 03:00 PM
  2. Denso Iridium Spark Plugs (Check this out) A spark plug journy....
    By bimmer328ci in forum 1999 - 2006 (E46)
    Last Post: 04-17-2007, 04:18 PM
  3. P0302 cylinder misfire code after checking spark plugs???
    By SpecialED in forum 1992 - 1999 M3 (E36)
    Last Post: 09-19-2006, 02:35 AM
  4. How do I check if my spark plug wires are still good?
    By JAlfredPrufrock in forum 1988 - 1996 (E34)
    Last Post: 06-01-2005, 12:45 PM
  5. Spark plug check
    By ///M LIFEŠ in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-01-2003, 04:07 AM
