I have these two things still laying around after doing my ZF swap a few years ago.
You can pick up both of them for $100.
Central Illinois.
Here's why.
The Getrag will pop out of first gear when you are starting from a complete stop, other than that it works fine.
There was a manufacturer recall for a defect in the guide sleeve for this transmission. I also suspect the shift fork for the 1st-2nd gears is bent which doesn't help. The PO didn't bother taking it in because the PO before that didn't bother taking it in before it expired.
The drive shaft is in good condition as well, had no issues previously before being taken out, you'll want to replace the CSB though.
This is a great deal if you want parts for your 5 Speed or have the patience to fix it. Or if you need another Driveshaft.
There you have it! $100 for both picked up in Central Illinois! Let me know if you have any questions.
Sent from my SM-G955U using Tapatalk
'95 325is in semi-rare Arctic Gray, clears, some ///M parts, and much more to come!
My Build Thread
