eBMWParts
Results 1 to 3 of 3
Thread: Clicking sound after replacing coilovers
    Jun 2017
    Freeport, NY
    2003 325i
    I replaced old coilovers with new ones and now there is a clicking sound when I turn. They are a different brand but I did not change anything. The only thing I noticed is the top sway bar end link on the left is higher than the right where it connects to the coilover. I connected them at the same height as on the old coilovers. Could this be the problem? I don't understand why the heights changed. I had the car jacked up evenly. There was no clicking with the old coilovers. Thanks in advance for any replies.
    Oct 2003
    Seattle
    99 M3
    What are you running?
    It does sound like something is loose.…
    Aug 2009
    Richmond, VA
    BMW M3
    First I would double check to make sure everything is torqued down correctly. Second, if I am understanding correctly one sides swaybar is resting higher then the other? If so, or if everything is torqued and you are still having the issue, then I would reinstall the swaybar end links while having the wheels preloaded if you did not do this originally.
  1. Knocking sound after replacing motor mounts
    By bmmer7 in forum 1996 - 2003 (E39)
    Last Post: 12-09-2012, 01:18 AM
  2. No sound after replaced the speakers
    By fastne39 in forum 1996 - 2003 (E39)
    Last Post: 02-19-2012, 09:04 AM
  3. Replies: 19
    Last Post: 11-13-2011, 05:35 PM
  4. Clicking Sound After I changed My Brakes and Rotors
    By E39Saloon in forum 1996 - 2003 (E39)
    Last Post: 07-02-2010, 08:26 AM
  5. clicking sound after driving
    By mesallem in forum 1996 - 2003 (E39)
    Last Post: 04-18-2008, 11:57 PM
