Results 1 to 16 of 16
Thread: 2000 Z3 2.8 Fuel Injector Error
    Nov 2005
    Satellite Beach, FL
    2000 BMW 540iT Dinan S2
    I get a recurring error on my 2000 Z3 2.8 (M52TU) with my Peake Reader (Table 15 Code 06) for Fuel Injector, Cyl #1. How can I verify I need a new fuel injector?
    - 2000 540iT Dinan S2 -2000 Z3 -
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    For those playing along at home, but don't have the magic decoder ring, it translates to a P0201 - #1 injector circuit open.
    How you verify depends on tools and knowledge. You could check the circuit with a DVOM and a scope. Or, failing electrical means, you could switch the injector to a different cylinder and see if the code follows. Labor intensive, resources light, and pretty foolproof.
    /.randy
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    If swapping, remember to depressurize that fuel rail 1st! Even so, you'll probably still smell like gasoline afterwards. When I did the 3.0 manifold swap on my 2.8, upon extraction of fuel rail and all injectors at once, the #6 injector got stuck in the manifold. I smelled (and tasted) like gasoline until my next shower.
    Nathan in Denver
    Nov 2005
    Satellite Beach, FL
    Can I use inpa to diagnose it?
    Dec 2007
    Great Dismal Swamp
    Nope, not beyond reading codes. INPA doesn't do ohm tests, or amperage tests, or visual inspections.
    /.randy
    Nov 2005
    Satellite Beach, FL
    Quote Originally Posted by rf900rkw View Post
    It can't see an analog value on the injectors? Or actuate an injector individually? I know I have been able to get some analog readings and actuate many features independently from it. And I misspoke when I said INPA, I should have included DIS.
    Dec 2007
    Great Dismal Swamp
    How is that going to help determine if it is the wiring, computer, connector, or injector?
    /.randy
    Feb 2004
    san diego
    ...it depands
    Don;t mean to troll or start a side conversation. But while reading this thread, I can't stop missing working at my last company with access to all Snap-on stuff like all-in-one scan tool that could perform OBC, ohm tests, amperage tests, and mitchell manual... But no visual inspection though; that was my job, sigh...
    2000 Z3 M Titanium Silver / Imola Red+Black Nappa
    2011 328i E92 Space Gray Metallic / Leder Dakota+Oyster
    Since 1987 12 euros / 2 kdms / 2 jdms
    - Zach
    Dec 2007
    Great Dismal Swamp
    Not to take it too far off topic, but I really dislike the all-in-one Snapon stuff. Heavy, bulky, and extremely limited. I have a saying in the shop. A test drive includes having a scanner; no scanner is just a joyride. The bulk of the Modis combined with the microscopic font that a 15yo couldn't read at a glance makes the equipment nearly useless for a dynamic test.
    A long while ago I went to work for a shop. They had bought into the Snapon promise that the top-o-line $15k scanner package would solve all of their diagnostic issues. After that failed miserably, they finally came to the conclusion that there was no substitute for paying for someone that could diagnose. That's when I came in. I had my own laptop based scanners, my own scope, DVOM... everything I needed, so I didn't use their Modis. This really really irked the owner. One day we were going to do a EPC response test on a Ford AX4N. This is where you put a pressure sensor on the line pressure port and then command the pressures up and down watching for misses, spikes and flutters. Well the owner insisted on doing it with the Modis. So we broke out all the the pressure transducer stuff, most still in the wrappings. It took a bit, but we uzzled out the connectors and patch cables, and wandered the cryptic menus until we got the scope in the proper settings. Finally up, the owner goes "okay, now what"? to which I inform him we now need a scanner in the car to issue the biDirectional commands to control the line pressure. The look on his face was priceless.
    No, I don't like all in one.
    /.randy
    Feb 2004
    san diego
    ...it depands
    So sorry to hear about the horrible experience, Randy.
    I suppose there is reason why they aren't doing so well. I agree that their older ones had serious usability issues. For what is worth, their refresh ones are definite improvements though. Peace!
    - Zach
    Nov 2005
    Satellite Beach, FL
    Just trying to avoid taking the fuel injection rail off more than I have to. Ever since my nutty vacuum leak on my wagon (all eight o-rings on the injectors to the manifold were leaking - looked like a locomotive on the smoke check), I am leery of removing them a bunch and damaging them.
    Obviously, I would have to take the fuel rail off to do this, but I figure that if I can use the software to actuate an injector, I can see the injector operate (or not). If it didn't operate at position 1, I'd switch 1 and 2 injectors and see what happened. Same test as what you are saying, but I only take the manifold off once. However, it sounds like your experience is to just switch them and drive it until the error comes up again.
    Jul 2004
    Houston, TX
    36 Cylinders
    If you have my INPA pack installed, you can use Tool32 to turn off one particular injector while car is running.
    MS42DS0.prg file; "steuern_ev_selektiv_ausblenden" Job, and in argument box put your cylinder number, and Start Job Once Only...
    Or run the "steuern_ev_1_aus" job directly, turn it back on with "steuern_ev_1"
    However I think it's still best to pop the fuel rail off, change all O rings, and replace faulty injector.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Dec 2007
    Great Dismal Swamp
    With the injector tree out, you could test #1 by activation, then if it fails swap 1 and 2 and retest. However, I think it would be easier to just ohm the circuit at the injector and the wire back to the DME. The other wire is constant power shared by all injectors, so if it is the problem, it would have to be right at the #1` plug.
    /.randy
    Nov 2005
    Satellite Beach, FL
    Thank you both. I'm definitely praying it is an injector and not the wiring harness. I hate tracing electrical issues like a broken wire...
    Jun 2013
    Boston, MA
    99 528i/5, 05 ZHP conv
    any update on this?
    Nov 2005
    Satellite Beach, FL
    Sorry, I got side tracked. Put in my rebuilt transmission in my wagon and we had to evacuate due to Irma. I will deal with it in a week when everything is back to normal.
  1. 2006 BMW 530xi with fuel injector error
    By BmwZr in forum 2004-2010 (E60,E61)
    Last Post: 07-11-2015, 06:12 PM
  2. 2000 e39 540i need fuel injectors.
    By BEAST 5 in forum 1996 - 2003 (E39)
    Last Post: 03-26-2012, 06:59 PM
  3. Getting Fuel Injector #3 Error Code?
    By Ali in forum Forced Induction
    Last Post: 03-24-2003, 08:58 AM
  4. Getting Fuel Injector #3 Error Code?
    By Ali in forum 1992 - 1999 M3 (E36)
    Last Post: 03-22-2003, 08:05 AM
  5. Getting Fuel Injector #3 Error Code?
    By Ali in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-21-2003, 11:20 PM
