Hello,
Does anyone know for a 2003 540 with Nav & DSP does the radio control (turn on) the amp, or does the amp control (turns on) the radio?
I'm trying to track down a slow battery drain and I'm wondering if I unplug the radio if that will then not allow the amp to turn on, or if I unplug the the amp, will that not allow the radio to turn on?
Thanks!
<== Steptronic Sealbeach740
2000 740i sport: 74k Green/Tan chrome MPars, clear corners, quad brake lights, AIC hi-beams, Hoen fogs, 16x9 screen, MKIV, TFT LCD screen in back, license plate backup camera with "on demand" switch, iPod audio/video (CDC/iPod audio switching, iPod video on 16x9 screen), Basslink, gauge rings, ///M pedals, switched steptronic +/- shifting mode, E46 paddle shifter steering wheel, Dinan engine & tranny software upgrade, DDEs controlled via Euro fog light switch, painted calipers with "BMW" lettering, windows up/sunroof close via remote.
2003 540i sport: 81k, Sterling grey/grey, MKIV Nav, PDC & CWP - Added license plate backup camera with "on demand" switch, paddle shift steering wheel, windows up/sunroof close via remote, Akebono's, painted calipers with "BMW" lettering, quad brake lights, iPod audio via AUX mode/video via 16x9 screen, BMW TV tuner, ///M pedals & gauge rings.
In a non-DSP system the radio turns on the amp. The DSP system should be the same.
Unplug to amp and see if your drain stops.
How about the FSU?
Thanks Jim.
The FSU was replaced around 5K miles ago for wacky fan operation (that is fine now).
So, if I put fuse 58 (10amp) back in, and disconnect the just amp (& the amp is the problem, and I realize mine won't be the first amp that has issues), I should see the same results as i when I had fuse 58 pulled out. If that's true, the problem should be the amp (vs. the radio being the culprit), right?
Thanks for the info.
