AFE POWER 77-46318 SCORCHER GT MODULE B46/B48/B58
DETAILS:
- Quick and easy plug & play installation without any modifications
- Around 30 minute installation
- Dyno tested and produced significant power increases of +50 HP / +72 lbs. x ft. torque
- Increase turbo boost to improve vehicle performance, efficiency and throttle response
- In-Cabin On-the-Fly Power Adjustments via LED light switch
- 4-power position settings: Stock (Green), Sport (Yellow), Sport+ (Orange) and Race (Red)
- Leaves no trace on ECU (No Footprint)
- High quality case & wire harness w/ factory style connectors
- High reliability, 100% of units tested
- Compatible with other aFe POWER performance products
A simple 30 minute install will give you a huge increase in power. The aFe POWER SCORCHER GT Module includes a high quality case & wire harness with factory style connectors for an easy plug & play installation. A LED light switch provides In-Cabin On-The-Fly power adjustments. The 4-Power settings are adjustable with one button and the LED light represent the settings: Stock (Green), Sport (Yellow), Sport+ (Orange) and Race (Red) . This performance module increase turbo boost. It improves vehicle performance and throttle response. In testing, this module resulted in significant +50 horsepower and up to +72 lbs. x ft. of torque verified by our in house dyno.
AFE POWER MOMENTUM GT COLD AIR INTAKE SYSTEM B58 M140 M240 340 440
DETAILS:
- +13 HP and +13 lbs. x ft. Torque max gains
- Outflows factory intake by up to 28%
- High Quality One-Piece Roto-Molded Sealed Housing with Auxiliary Air Scoop
- CAD-Designed Roto-Molded Intake Tube
- Lightweight high gloss, clear-coated 2 x 2 twill-weave carbon fiber trim on housing for styling
- Built-In Sight Window Provides Easy Inspection of Filter Without Disassembly
- Pro 5R oiled 5-Layer Progressively Finer Mesh Cotton Gauze Oiled Media for Maximum Performance
- Unique (Patent Pending) Filter-to-Housing Interface for Easy Installation
- No Cutting or Drilling on factory Parts for Faster Installation
Unique One-Piece High Quality Housing W/ Auxiliary Inlet:
The smooth one-piece (Patent Pending) high quality sealed housing with auxiliary air inlet is used to eliminate the use of multiple-piece housings and ensure the coolest air intake charge available. A large, clear sight window is used for a hassle-free filter inspection and an aggressive style.
AFE POWER MAGNUM FLOW AIR FILTER B46/B48/B58
DETAILS:
- Oil-Free, Pro DRY S 3-Layer Progressive Porosity Synthetic Media for maximum convenience
- 100% Polyurethane Frame On All Sides For Extra Long Filter Life
- Washable and Reusable for Multiple Cleaning Cycles
- 25mm Deep Rounded Open Pleats
- Progressive Bump Seal Design for a Perfect Fit
Pro DRY S Media:
This filter features 3-layers of progressive media to provide maximum flow with excellent filtration. The progressive layering of media allows the filter to flow at high levels even when dirty. The Pro DRY S non-oiled synthetic air filter requires no oils for cleaning for maximum convenience
AFE POWER MACH FORCE-XP 3" TO 2-1/2" 304 STAINLESS STEEL EXHAUST SYSTEM B58 340 44
DETAILS:
- +14 HP and +13 lbs. x ft. Torque max gains
- Constructed from 100% hand TIG-welded, 3" to 2-1/2" mandrel bent, brushed finished 304 stainless steel tubing
- Includes a factory style exhaust valve
- Utilizes a unique high flow, transverse muffler with a high-temp powder-coated black finish
- Includes dual 4" diameter, gloss black, 304 stainless steel tips
- Factory style V-band flange for a secure leak-free seal
- Uses all factory hanger locations for a hassle-free installation
Aggressive Sound:
A free-flowing, transverse muffler is used to absorb high pitch tones producing a powerful sound and unleashing all available horsepower and torque. The muffler is finished with a high-temp powder-coated black finish and a stamped aFe power logo.
