AFE POWER MOMENTUM GT AIR INTAKE SYSTEM 230 330 430
DETAILS:
- +13 HP / +12 lbs. x ft. Torque max gains
- Outflows factory intake by up to 14%
- High Quality One-Piece Roto-Molded Sealed Housing with Auxiliary Air Scoop
- CAD-Designed Roto-Molded Intake Tube
- Built-In Sight Window Provides Easy Inspection of Filter Without Disassembly
- Aluminum Heat-shield to protect the housing from the turbocharger heat
- Pro 5R oiled 5-Layer Progressively Finer Mesh Cotton Gauze Oiled Media for Maximum Performance
- Unique (Patent Pending) Filter-to-Housing Interface for Easy Installation
- No Cutting or Drilling on factory Parts for Faster Installation
Unique One-Piece High Quality Housing W/ Sight Window:
The smooth one-piece (Patent Pending) high quality sealed housing with auxiliary air inlet is used to eliminate the use of multiple-piece housings and ensure the coolest air intake charge available. A large, clear sight window is used for a hassle-free filter inspection and an aggressive style.
AFE POWER MAGNUM FLOW AIR FILTER B46/B48/B58
DETAILS:
- Oil-Free, Pro DRY S 3-Layer Progressive Porosity Synthetic Media for maximum convenience
- 100% Polyurethane Frame On All Sides For Extra Long Filter Life
- Washable and Reusable for Multiple Cleaning Cycles
- 25mm Deep Rounded Open Pleats
- Progressive Bump Seal Design for a Perfect Fit
This filter features 3-layers of progressive media to provide maximum flow with excellent filtration. The progressive layering of media allows the filter to flow at high levels even when dirty. The Pro DRY S non-oiled synthetic air filter requires no oils for cleaning for maximum convenience.
AFE POWER 77-46318 SCORCHER GT MODULE B46/B48/B58
DETAILS:
- Quick and easy plug & play installation without any modifications
- Around 30 minute installation
- Increase turbo boost to improve vehicle performance, efficiency and throttle response
- In-Cabin On-the-Fly Power Adjustments via LED light switch
- 4-power position settings: Stock (Green), Sport (Yellow), Sport+ (Orange) and Race (Red)
- Leaves no trace on ECU (No Footprint)
- High quality case & wire harness w/ factory style connectors
- High reliability, 100% of units tested
- Compatible with other aFe POWER performance products
A simple 30 minute install will give you a huge increase in power. The aFe POWER SCORCHER GT Module includes a high quality case & wire harness with factory style connectors for an easy plug & play installation. A LED light switch provides In-Cabin On-The-Fly power adjustments. The 4-Power settings are adjustable with one button and the LED light represent the settings: Stock (Green), Sport (Yellow), Sport+ (Orange) and Race (Red) . This performance module increase turbo boost. It improves vehicle performance and throttle response.
