Page 2 of 2 FirstFirst 12
Results 26 to 39 of 39
Thread: Spring Rates for TC Kline DAs
  1. #26
    CT
    M3
    That is definitely good to know
    If anyone else with Koni based shocks is looking for a more economical place to have them rebuilt I found these guys:
    http://racingeclipse.com/services/custom-shock-services
    They said rebuilds will be in the $125-150 range as they are not a Koni dealer and need to purchase parts from another vendor but that still beats paying $200 for Tru Choice or Pro Parts as Koni no longer rebuilds their own shocks in Kentucky.
    Justin with RE said he could revalve to Konis to handle whatever spring rates I desired which might be the way to go so I have more options here.
  2. #27
    Bellingham, WA
    1998 M3, 2001 530i
    I run 336 front, 448 rear (Swift metric springs) on my TCK DAs. With really big sways. It's perfect for the street, but I bottom out the fronts on one section of my local track. I think I just convinced myself to go up to 392/504.
  3. #28
    Los Angeles, CA
    #Project333Ti & Z3 Coupe
    How many miles is everyone getting out of their DAs? I have about 20k street and canyon miles on mine.
    Also, I just called Racing Eclipse, and they 100% DO NOT do Koni anymore.
  4. #29
    CT
    M3
    Quote Originally Posted by e30polak View Post
    Weird that they said that to you. I called this week was given Justin's cell phone number and he said they could rebuild Konis no problem. Pm me and I'll give you his number.
  5. #30
    Aug 2009
    Metro DC
    79 323i, 94 325is, 13 M3
    According to the manufacturer's representative, Konis never wear out, you just need to set the rebound a little bit stiffer and it will get you back to where you were in new spec. He said he expected six-figure mileage out of a set unless somebody was really banging the gators constantly at the track, OR bottoming them out repeatedly. Apparently if you're the original purchaser with a receipt, they are lifetime guaranteed. The auto business is kind of a sideline for them. Their main business is railroad cars, thus the durability.
    If God meant for man to motor-swap LS engines into track cars, He wouldn't have created Corvettes.
  6. #31
    Nov 2005
    MA
    Cayman S, Golf GSW, E30
    I got a used set of TCK DAs a couple seasons ago. They're the older gold bodied ones. The rears were leaking so i had them rebuilt at ProParts. Interestingly, they dyno'ed perfectly fine before the rebuild, but I chose to rebuild anyway to run an updated valve which supposedly quiets them down a bit (the rear TCK DAs like to make clunky noises 'by design') and a bigger machined bushing at the rebound adjuster which is more robust. The fronts I never had rebuilt, but i can still tell the difference between quarter turn adjustments so it seems they still work fine. These are probably 6-7 years old, but mostly track miles.
  7. #32
    CT
    M3
    Quote Originally Posted by TXBDan View Post
    Dan what spring rates do you run on your DAs and do you know how much spring rate proparts said the rears are good for after the rebuild?
  8. #33
    Nov 2005
    MA
    Quote Originally Posted by VRT View Post
    See post #16
    I had mine rebuild to original TCK specs, but ProParts said they could change the valving to accommodate different/higher spring rates. Not sure how high they could ultimately go.
    If i keep these shocks, i'm going to run 600/700 next year. I can swap my current rear springs to the front and just get new rears. (if anyone wants to buy these and force me to buy some MCSs just give me a ping :P)
  9. #34
    CT
    M3
    Ahh I missed that, I just got off the phone with True Choice in Ohio and can put this one to rest for everyone
    The TC Klines are valved to work best with 300-600lb springs out of the box. They will handle 700 but that is not ideal. With a revalve the sky is the limit and they said I would have no problem running 5-800lb fronts and 7-1000lb rears.
  10. #35
    California BAY AREA
    e30 M3, 335d
    I have been running a set of TCK D/A on my E36 M3 for 3 seasons now (HPDE advanced group, 8-10 events a season) with an H&R Front sway. Rates I went with are 600 front, 700 rear and I have zero complaints about this setup. I am running -3.5˚ of camber up front but the car is very very predictable and will rotate easily if needed. Just my .02
    - Max
  11. #36
    Mar 2006
    New York, NY
    Z4 M, X3 35i, 550i
    Did the rebuild actually quiet them down? My rear right has the most annoying rattle..:
  12. #37
    Trussville, Alabama
    95 BMW M Techniq SCCA Ep
    Good information, but I would like to know front and rear toe, front caster, and ride height at the jacking points, front and rear....suggestions?
  13. #38
    Nov 2005
    MA
    Quote Originally Posted by Dubbedown View Post
    Maybe a little, but not much. They're still annoying on slow (<35mph) rough roads. Once you're up over 35mph or so the noise goes away and of course there's no noise on smooth or even average roads. I also tried installing the rubber orings like some have suggested, but it didn't do anything. Fortunately, i rarely drive the car on the street so its not a big deal for me.
  14. #39
    Mar 2006
    New York, NY
    Z4 M, X3 35i, 550i
    Your experience sums up mine as well
  1. Replies: 1
    Last Post: 07-25-2016, 12:01 PM
  2. Spring rates for TC Kline coilover kit
    By cjc9 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-28-2010, 11:06 PM
  3. Other uses for TC Kline spring perches
    By Car54 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-31-2008, 10:46 PM
  4. TC Kline DA coil overs for E30
    By S14 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 06-05-2007, 07:46 AM
  5. TC KLINE DA COIL OVER Kit for E36
    By edouble33 in forum BMW Parts For Sale
    Last Post: 09-27-2006, 06:18 PM
