Hey guys I picked up a used set of TC Kline Double adjustables for my E36 M3 track car and have been going back and forth about what spring rates and sizes to get. So far I have looked at hypercoil springs but would be open to swifts or any comparable brand.
Choices are
Front: 60mm 6" 600lb / 60mm 6" 650lb
Rear: 60mm 6" 700 pound / 2.25" 5" 700 pound / 2.25" 5.5" 750 lb
I would be open to any rear height adjuster to make this setup work too.
I've done my research and the consensus seems to be that you want a 100lb difference between front and rear and that the TC Kline konis don't handle more than 700 or 750 lb springs depending on who you ask.
What say you?
I like a 150 split myself. 650 minimum on the front so that leaves you with an 800 rear. But you know what they say about opinions
Currently I'm running 580/650 and not liking it. I mean it's fine for 8/10's driving which is essentially what I'm doing right now since I do DE's to relax from my normal race car.
I thought TCKline DA's handled more spring than that? Maybe with custom valving? If anyone should know, it's them.
Don
When I bought TCK SA's, they informed me the SA's are good up to about 650-700 on the rear. But that the DA's handled more. I can't remember how much more, but it was significant. Give TCK a call.
I'd run 600 front, 700 rear. I am currently running a 150 split and find the car is a little loose. You could try the 750s but I think you may find the 5.5" springs are too tall.
For ride height adjusters, I would stay away from the GC articulating ones - by the time you get them low enough to get the rake correct (0.75") they no longer articulate. Besides that, they're a lot more difficult to install and adjust than I would have thought (IMHO).
These specifically fit the 2.25" springs you're running - and they're only $105/pair.
https://www.iemotorsport.com/bmw/E36...E36rspadj.html
2002 BMW M Roaster.
1998 BMW 328is SCCA E Production road racer.
I wouldn't go above 700lbs with TC Klines. I would also go with Hypercoil springs as you mentioned. Depending on the length, they usually have one less coil. They also test all their springs when they are completed and match them together, ie. a batch of 700lbs springs all don't come out exactly 700lbs.
My Current Garage:
Thanks for the heads up on the Ireland Engineering rear height adjusters, that's a great price and they include the top mount
I gave TC Kline a call and they said the max spring they would run on the DAs in 700lb however they recommended 400 500 or 500 600 and explained that in their experience the higher 600 700 and up spring rates are faster with fresh Hoosiers however once the tires have a few heat cycles on them the lower rates are actually preferable. They also recommended a 28mm front bar and a stock rear bar which is contrasting to the 600 700 rates and 33 25 bars recommended to me be by Bimmerworld.
What do you guys think about their recommended rates? I recently made the jump to entry level rcomps (maxxis RC1) and will most likely get into Hoosiers down the road but am not trying to get ahead of myself.
I am not sure whose word I would place the most weight to but one thought - are you going to drive this car on the road at all? If so, I would go with the lower spring rate.
My Current Garage:
650 / 700 with the DA's here, I haven't tried other rates with these, but they feel good
Just to thrown in my 2c, I run 400/500 spring rate on my TCK D/A's, my car is almost exclusively a track car and I compete in Time Trial in California.
I won all three events this year and the car is very competitive.
Now, I run a huge (the largest) front bar GC sells along with a stock rear bar. The car does have a lot of body roll but has phenomenal amounts of grip. Body roll is not always your enemy. I think it's mainly down to driver preference tbh.
I call TC himself to discuss my setup and he said stick with the spring rates I have. I *might* try a little stiffer end of this year as an experiment but you can't argue with results and TC has won a ton of stuff himself...
Pics on Track showing body roll:
It's a dedicated track car and the only street use it sees is driving to the track and back which should stop when I get my trailer setup properly
Seems like the majority likes the 600-700 rates for these coilovers. I guess the question is has anyone driven with both those and softer springs for comparison?
I'm still working out the handling on my race car. I am using
650f
800r
GC medium front bar
GC small rear bar
I think it's good mid corner, but I struggle getting off the corner and and fighting an odd push that seems entirely related to how much the steering wheel is turned.
Anyway BW suggested 800/900 for me. After winning an SCCA majors with the 650/800 setup I decided to try the 800/900 setup the next day in the same tires. I personally hated it and was 3+ seconds slower.
That said, many people are fast with 900/1000 and even more with aero.
My next test day I will try 550/700 and I think I will reserve judgement til I try it.
2002 BMW M Roaster.
2002 BMW M Roaster.
Setup is going to be very personal. It'll really depend on your driving style and what you like. Best bet is to try several different spring rates during a test and tune and dial in what you want.
'03 911 Turbo 6MT fun car
'18 Toyota Land Cruiser Daily driver/Ski Machine/Off Roader
'15 Cayenne Diesel Wife's DD
'17 KTM 690 "Adv" 2 wheeled Adventurer
I'm going from 550/650 to 750/900... Will post results.
I ran 450/500 with TMS swaybars on soft and i'm now running 500/600 with stock sway bars. It's odd how set TCKline is on soft rates. He swears he's fast and wins on rcomps on 450/500 all day long. He also told me 700 is about as high as he'd recommend for the shocks.
The 500/600 + stock sways setup is too soft. Even on NT01s I get a lot of body roll and have much more outter tire wear than with the other setup. A bigger front sway bar would likely correct this, but i can't run one for classing points reasons. I think the R1-Ss i run for TTs would be happier with stiffer springs as well from what i gather. If i run these shocks next year i'll likely go to 600/700 over the winter. The car is pretty easy to drive, safe and predictable, and the balance is good, though.
What camber were you using with the NT-01's?
-3.8 ish.
I just made the jump to r comps (maxxis rc1s) which have a stiffer sidewall than the nt01s. Following that logic would I want less camber maybe -3.5ish?
It depends on your front/total roll stiffness too. If the car is very soft, you'll need more neg. camber. I've always run -3.5deg and it was perfect with the front swaybar, but now that i'm on a stock front swaybar, i need more neg. camber. Too much neg camber will start to compromise braking performance so you need to find the sweet spot.
^This.
On my E36, I've been running -2.5 rear. I have a gut feeling that may be a tad too much for ideal tire wear, but my car is so balanced, I'm afraid to F with it.
Makes sense and it sounds like I need to get a home alignment rig to dial this thing in without spending $150 every time I want to make a change.
I haven't put the TC Klines on yet and have been running BC SA coilovers with 10k (560lb) 14k (784lb) springs and it seems to work well for an entry level setup. With the 200lb difference in springs I've been running a 27mm front bar and no rear bar along with 3.0 degrees front camber so I can drive to the track.
Thinking 3.5 F & 2.5 R would be a good starting point assuming I either trailer or drive to the track with a set of throw away tires
