RM European Auto Parts
Page 2 of 2 FirstFirst 12
Results 26 to 29 of 29
Thread: ecm failure?
  1. #26
    Buffalo N.Y.
    85 325 stroker
    Well going of what he said, the pro3 cars where basically locked at 185rwhp. He believed that with a 2.7 bottom end, a red chip ecm, and a hot cam, I should land in the 225-245 range. I will most likely out it on his chassis cynical when I'm done just because I can, and it would be nice to have a benchmark, a real world figure.
    Not too excited about the 3k, but it will be so much fun when I'm done that I doubt I will care!
    Damn autocoerect! Put it on his chassis dyno
    Perhaps this should move to a new thread on building a stroker I motor!
  2. #27
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    We will all greatly look forward to watching your rebuild, at this forum. I hope you'll share - we're all BMW techie / driver guys here.
    I can't tell you how much I'm dying to see the dyno numbers. If your creation makes that much power, in that displacement, for that little money, who'd want two cams? PLEASE share the details here!
    In fact, I'm sure Jim Levie will join us any time now, and lend some of his immense E30 experience. No one knows the E30 better.
    Chris Powell
    BMWCCA 274412
  3. #28
    Dec 2004
    Huntsville, AL
    87 325is
    I agree with Chris. There is no way a stroker will reach 240hp. From what I've seen, 180hp would be more like it with a pretty aggressive cam and dyno tune. $3k for parts isn't unrealistic for a stroker build.
    I assume that you will replace the rod and main bearing when you put the engine back together. Take note of what The Bentley says about selecting the "color" of the bearings. The diameter of the journals must be checked to a tenth to pick the right "color" bearings. If you are lucky, you will be able to use one "color" main and rod bearings. But, on occasion, I've had to use two or more "colors" when building an engine.
    Jim Levie, Huntsville, AL
  4. #29
    Buffalo N.Y.
    85 325 stroker
    Now that's a good tip! Thank you! Most engine builds I have ever been involved with where all straight forward. This is my first complete euro engine build, and I want to make sure I get everything right. And ihave discovered with German engines, it MUST be done exactly correctly. So please keep such advice coming Guys!
  1. ecm failure on z3 3.0 coupe
    By trubey in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-26-2010, 09:43 PM
  2. Anyone experience balljoint failure?
    By Greg in forum 1992 - 1999 M3 (E36)
    Last Post: 06-11-2001, 02:55 PM
  3. low beam + tail light failure on OBC
    By Changster in forum 1992 - 1999 M3 (E36)
    Last Post: 05-24-2001, 01:12 AM
  4. Question about rear subframe failure
    By Jeff P in forum 1992 - 1999 M3 (E36)
    Last Post: 04-11-2001, 02:26 PM
  5. Tail light failures - not OBC message
    By Alex '94 325i in forum 1991 - 1999 (E36)
    Last Post: 03-21-2001, 11:51 AM
