Results 1 to 3 of 3
Thread: MAF/VAF Issue
    Aug 2017
    San Jose, CA
    2007 Mini Cooper S
    MAF/VAF Issue
    My car is a 2007 Mini Cooper S and it is misfiring the OBD says there is a problem with the MAF. Where is this sensor located and can this be just cleaned or does it have to be replaced? Thnx to anyone who can help!
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    The mass air flow sensor is installed between the air filter housing and the intake manifold, to monitor air flow into the engine intake
    example : Mass Air Flow Sensor Testing http://www.pelicanparts.com/techarti...or_Testing.htm
    Use this link to ind the part number for your model and built year http://www.realoem.com/bmw/select.do
    Dec 2013
    Chicagoland area
    EXOTICS
    You can make an attempt at cleaning the MAF instead of replacing it first.Use CRC MAF Spray Cleaner, do NOT attempt to physically TOUCH the film to clean it!Let dry before powering-up MAF or starting the vehicle.
  1. Maf Voltage issue
    By 200kclub in forum 1983 - 1991 (E30)
    Last Post: 07-26-2013, 08:44 AM
  2. MAF my issue?
    By maxxon19s in forum 1999 - 2006 (E46)
    Last Post: 02-09-2013, 02:33 PM
  3. MAF sensor issue
    By 99silverfox in forum 1996 - 2003 (E39)
    Last Post: 06-14-2011, 02:42 PM
  4. Code #1215... MAF Sensor Issues?
    By fehder in forum 1992 - 1999 M3 (E36)
    Last Post: 06-20-2010, 10:26 PM
  5. Code #1215... MAF Sensor Issues?
    By fehder in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-16-2010, 03:13 AM
