Results 1 to 4 of 4
Thread: Windows won't go up
    Aug 2017
    Oakland, California
    1995 e34 525i
    Windows won't go up
    1995 525i Windows won't roll up, any suggestions as to what it could be. All 4 stopped working at the same time along with the sunroof.
    Jul 2006
    Ojai Oh Hi!
    x5 330i 525i all stick
    Same thing just happened to me. Check the fuses under the back seat on the driver side (17amp I think) - should be this
    Did you check the under hood fuses as well?
    Virginia
    95 525, 93 M5, 05 X5 x2
    Have you checked relays. These are located in the engine compartment fuse box and under the back seat. Also, the general module could be faulty. It's also located in the main fuse box. Look up images of E34 fuses and relays. There is one which has all the relays labeled with functions.
    Dec 2011
    Lancaster CA
    e34,e38,e39,e46,e70,e90
    Check the fuses as stated above, if good, I think this is a main fuse link problem. The main fuse link is under the rear seat, close to the battery, looks like a big fuse inside of a plastic shield...thus, the fuse link.
  1. Windows won't go up. . .
    By FOXHOUND in forum 1991 - 1999 (E36)
    Last Post: 01-30-2005, 12:28 PM
  2. Windows won't go up/down - but sunroof works??
    By LinearX in forum 1991 - 1999 (E36)
    Last Post: 10-05-2003, 03:07 AM
  3. Windows Won't Go Up Help!!!!
    By BRUNO in forum 1991 - 1999 (E36)
    Last Post: 08-26-2003, 09:11 AM
  4. Auto Window Won't Go Up
    By bimmerpwr in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-28-2003, 10:22 AM
  5. Windows won't go up on one touch ?
    By ///Arman in forum 1992 - 1999 M3 (E36)
    Last Post: 08-26-2002, 09:46 PM
