Results 1 to 8 of 8
Thread: Foxwell/Schwaben scan tool question
    Sep 2012
    Orlando, FL
    2001 E38 740i Sport
    Do I need to use the round underhood connector on my 3/2001 build 740? I just got the Foxwell scan tool and using the OBD2 Port in the console, there is a lot that I am unable to access. I don't want to buy the OBD2 adapter for the underhood connector if that's not the problem.
    Jun 2013
    NJ
    e36 M3/4/5, 08 M5 6sp
    what are you trying to access?
    Sep 2012
    Orlando, FL
    2001 E38 740i Sport
    I was just playing with some of the sub-menus, for example, when I clicked on the IHKA and other body modules, I received an error. Not trying to do anything in particular.
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Sep 2012
    Orlando, FL
    2001 E38 740i Sport
    Quote Originally Posted by Mayorchuck View Post
    Thanks!!
    Jun 2005
    Florence KY
    1998 BMW 740iL
    I have that scanner and to access fully all the modules I have to use the round connector under the hood. When I use just the OBDII I have limited access.
    Just keeping it reliable and looking decent.
    Sep 2012
    Orlando, FL
    2001 E38 740i Sport
    Problem solved with jumper wire in the 20-pin cap. Thanks!
    Nov 2009
    culver city ca
    95 740i, 52 chev
    I have Schwaben scanner BMW/Mini 14020sch purchased with the round 20 pin plug having 1995 740i OBD1, can one use to code? manual says so but no info on how! Installed Xenon headlights from same year 750 so I get the message "check low beams"! When I plug into the round 20 pin with Ignition in #2 postion all I get is seat faults! + 8F IKE KOM Inst fault stored, + 1 LM light module fault stored + C9 Eng DME DMS Digital motor electronics fault stored, D2 etc. no numbers like their is in Bentley manual. I purchased scanner thinking scanner would help me find why engine starts running rough with no power after about 1 minute after start! Where I'm I goofing at? To me right now it appears I wasted $200. purchasing
  1. Peake Scan tool Question, Flashing "E"
    By cnd325i in forum 1991 - 1999 (E36)
    Last Post: 03-05-2017, 06:47 PM
  2. NEW Schwaben/Foxwell BMW Scan Tool help
    By nomadichln8 in forum Diagnostic Software
    Last Post: 04-05-2016, 12:22 PM
  3. Scan tool question ???????????
    By SOCIALGENIUS in forum 1995 - 2001 (E38)
    Last Post: 06-06-2010, 06:49 AM
  4. New E36 M3 owner, Scan tool question
    By Kiprugod in forum 1991 - 1999 (E36)
    Last Post: 02-26-2009, 09:09 AM
  5. scan tool question
    By drsides in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-01-2006, 07:39 PM
