Results 1 to 11 of 11
Thread: Front blinker bulb stays on??
    Dec 2012
    NC but always everywhere
    '99 BMW M3 Coupe (Dakar)
    My right front turn signal bulb filament stays lit all of the time when the lights are on. The side marker and the rear turn signal blink fast when selected but the front just stays on solid regardless if selected or not...as long as the lights are on both filaments stay lit.
    Any idea on a fix for this?
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    The front, fender and rear turn signal bulb are all on the same circuit. I would check the front built first, it could be internally shorting since it is a dual contact bulb; marker light and turn signal.
    [IMG][/IMG]
    Dec 2012
    Quote Originally Posted by AJLM34A View Post
    New bulb. Old one did the same thing. :/
    Dec 2012
    Pretty sure it's a grounding issue.
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Quote Originally Posted by Rooster20 View Post
    What makes you say that? The bulb being on means there's power and ground there completing the circuit. Test your wires with all three bulbs. Pull your marker and rear bulbs out leaving in just the one in the front and see if it still does it.
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    Are you sure it is the correct bulb? Swap the other side over. When I have seen this, the bulb was only a single filament
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
    Dec 2012
    Quote Originally Posted by BMWManiac View Post
    Yea it's the correct bulb.
    Reason I say it's a ground is because a close friend of mine who's a head Porsche tech is saying that's very likely what it is.
    Feb 2002
    Orlando, FL
    There is a stud with locking nut on both side of the fender, right behind the headlight where all the grounds are run. Check there, and then I would check inside the housing of the corner lamp/bulb connector to make sure there isn't any issues with grounds
    Dec 2012
    Thanks! Yea looking for a wiring diagram was next on the list.
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    The front marker light should be a dual contact, maybe a 12v21w bulb. There should be a 3 wire connector for it, X137, pin 1 ground, pin 2 right front turn light, and pin 3 right park light.
    http://wedophones.com/Manuals/BMW/19...g%20Manual.pdf
    Start at section 6313.0 and scroll through 6314.0
    [IMG][/IMG]
    Dec 2012
    Thank you
  1. Left blinker sometimes stays on
    By mrdane in forum 1991 - 1999 (E36)
    Last Post: 07-12-2006, 11:45 AM
  2. Legality of white front blinker bulbs in various states?
    By 325rider in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-12-2006, 01:41 AM
  3. Brake light in dash to replace bulb stays on
    By almostki in forum 1999 - 2006 (E46)
    Last Post: 09-18-2005, 01:13 PM
  4. How do you change the front blinker bulb?
    By Aren G in forum 1999 - 2006 (E46)
    Last Post: 11-18-2003, 12:49 PM
  5. need help changing front blinker bulb
    By scrtagt69 in forum 1999 - 2006 (E46)
    Last Post: 01-16-2003, 10:08 AM
