Results 1 to 5 of 5
Thread: M20 Alternator Voltage output?
    Frederick, MD
    '87 e30, '02 e39 Dinan
    Curious what everyone is seeing for voltage output. I have gone through numerous alternators and they all seem to output between 12.6 and 13.2
    Nothing higher.
    What do you guys see?
    Capital Driving Club Car # 102
    How to turbo your car:
    Step one. Install ecu and learn to tune and or have it tuned.
    Step two. Install injectors and retune.
    Step three. Install turbo parts and bits. get it running with out leaks. DO NOT DRIVE IT. Idling should be ok
    Step four. Retune car
    Step five enjoy
    May 2009
    Charlotte, NC
    e30 e46
    Seems a bit low. Any chance you are using an analog meter, they need to be calibrated.You could always drag them down to your local auto parts store that has a test rig.Good luck.
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    How/where are you measuring it? What rpm?
    "Howdy, Folks!"
    Dec 2004
    Huntsville, AL
    87 325is
    The system voltage, with a fully charged battery should be 13.6v at 750rpm. It should rise to about 14v above 2000rpm.
    Jim Levie, Huntsville, AL
    Frederick, MD
    This was all through megasquirt. So what my ecu is seeing for voltage. I have compared this number before to the battery via a volt meter and its pretty similar.
    Next question. I currently have a rebuilt bosch. It has been returned once. New one is doing the same thing.
    Where do i get a good alternator from? that will last?
    Step five enjoy
  1. Low alternator voltage output at startup
    By Rich in Boston in forum 8 Series (E31)
    Last Post: 08-11-2011, 11:15 AM
  2. Alternator Voltage Output
    By SPL15 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-13-2009, 07:16 PM
  3. m20 alternator question
    By Vin Diesel in forum 1988 - 1996 (E34)
    Last Post: 11-09-2007, 08:23 PM
  4. Throttle body voltage output S52?
    By hotshu in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-24-2006, 05:09 PM
  5. Battery and Alternator voltage question...
    By Phu Nam in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-25-2005, 10:33 PM
