Page 4 of 11 FirstFirst 1234567891011 LastLast
Results 76 to 100 of 262
Thread: Turbo e30 street car
  1. #76
    Frederick, MD
    '87 e30, '02 e39 Dinan
    Well sorta sucessful day, got her up and running on e50 so far. time for celebration.
    20190103_142658 by euro2fast4u, on Flickr
    20190103_143410 by euro2fast4u, on Flickr
    20190103_142730 by euro2fast4u, on Flickr
    Again Blue and Green are e9 slightly up hill and slightly down hill. Red was a new flat road i found.
    e30 power8 by euro2fast4u, on Flickr
    My assumption is i added about 4° total however at 50% i think there is about 2 degrees more timing all around.
    Capital Driving Club Car # 102
    How to turbo your car:
    Step one. Install ecu and learn to tune and or have it tuned.
    Step two. Install injectors and retune.
    Step three. Install turbo parts and bits. get it running with out leaks. DO NOT DRIVE IT. Idling should be ok
    Step four. Retune car
    Step five enjoy
  2. #77
    Apr 2006
    Minnesota eh?
    86 325es
    if you make a timing change is that virtual dyno program repeatable enough to see it?
  3. #78
    Jul 2005
    California
    Bima
    you gas is over a $1 cheaper than mine
  4. #79
    Nov 2011
    Derby UK
    1999 BMW540 Supercharged
    Were those pump prices for ltrs or gallons ??
    1999 540 Auto with Eaton M112 supercharger
    Airlift 3H/P management, M5 steering box, M5 LSD, Eibach/Dinan front and rear anti roll bars, PM Modifich door boards, 4 Eton 6.5s, Sound Magus VS3500.1, 2 x 10" Kove audio subs, Alpine ICS X7 Headunit, 19" BBS Hammer Sports RT245/RT246, Muffler delete, electric coolant fan.
  5. #80
    Frederick, MD
    Eh i would its possible but i have not been able to. If you had a clear road where you could accellerate every time on at the same point then possibly. For me i tend to always avoiding traffic but i try to do it at the same part of the road.
    Quote Originally Posted by Robocop View Post
    Ha this place is the cheapest and usually doesnt have good gas however it is the only one with e85. I was shocked at how much cheaper it was then high test.
    Quote Originally Posted by Kenny1958 View Post
    Per Gallon.
    Drove it again today and cold start needs some more work with the e50. I heard of this in the past so i will see if i can tune this out of it given i can fill up on e85 almost always. Station is 6 miles away from me.
    Step five enjoy
  6. #81
    Frederick, MD
    Cold start is beginning to be an issue again, however i am not really sure how to handle the e85 cold start tune vs pump gas tune. I am wondering if i should have two similar tunes one for each or if i can tune it at around 50 and get the best of both worlds. Thoughts?
    Also i have started back up on the wet sanding am making some progress moving around the car, panel by panel.
    Step five enjoy
  7. #82
    Frederick, MD
    Body work progress
    20190119_154836 by euro2fast4u, on Flickr
    20190119_154839 by euro2fast4u, on Flickr
    20190119_154842 by euro2fast4u, on Flickr
    20190120_120518 by euro2fast4u, on Flickr
    20190120_122721 by euro2fast4u, on Flickr
    20190120_130940 by euro2fast4u, on Flickr
    20190120_132754 by euro2fast4u, on Flickr
    20190120_142254 by euro2fast4u, on Flickr
    20190120_142256 by euro2fast4u, on Flickr
    20190120_142300 by euro2fast4u, on Flickr
    20190120_161907 by euro2fast4u, on Flickr
    20190120_170039 by euro2fast4u, on Flickr
    Step five enjoy
  8. #83
    Frederick, MD
    Any one have any opinions on this clutch?
    Talked to Rob and was told the Multipuck can hold around 620ftlbs.
    Take these with a grain of salt. Was more curious then anything, no idea on the accuracy of it however the track doesnt open up until march. The purple line was from me trying to shift quickly and the clutch said no hahaha. fudge.
    Filled up with some more ethanol, now at around 68%. I can feel my car surging as i accelerate under light load. Wondering if my pumps cant handle it now. Will check duty cycle from the logs.
    Step five enjoy
  9. #84
    Frederick, MD
    Replaced the oem lift pump. Appears to be dated 87 so its had a long life hahah. Upgraded the wire and created a new relay fro the 450lph in tank pump. More modification then i expected to get it all to fit. I may redo it but for now it should work. Unfortunately i have to re-tune the fuel maps including the cold start :/ drats. Good news is i should be quicker at getting it done.
    20190209_140248.jpg20190209_141846.jpg20190209_141924.jpg20190209_160934.jpg20190209_143832.jpg
    Never got a photo of the wiring :/
    Step five enjoy
  10. #85
    Jul 2005
    California
    Bima
    did your tune get way richer as is with the 450 pump vs stock?
  11. #86
    Frederick, MD
    Yea it did but it is pretty consistent overall. I pulled some fuel out across the board and seems to drive fine again. The more i am thinking about it the more i think im probably just bypass most of the fuel at the pressure relief. My clutch wont hold so been looking at the DKM/CCM one
    http://www.cesmotorsport.com/documents/products.html
    Wont even hold at 4 psi now
    I plan on putting it back on pump gas and checking the fuel map. I can compare the two for you to see what the difference is.
    Step five enjoy
  12. #87
    Mar 2016
    Australia
    e30 318i, 135i
    what idle fuel pressure do you see with the 450? I've been debating fitting mine because I'd read that it overpowers the stock FPR and return line i.e. won't idle at 43psi
  13. #88
    Frederick, MD
    No idea again i have the 450 feeding a 255 feeding 600cc injectors. It looks like a while ago i replaced the fuel line from the tank to the 255/filter setup to a larger size. However everything else is OEM sized. I felt surging part throttle in the past on e85. I will say i do not now, but the clutch issue limits testing.
    I need to install a fuel pressure sensor and log. Right now it could be anything. But it does cold start sub 35°f on e85 so it cant be that bad.
    Step five enjoy
  14. #89
    Jul 2005
    California
    Bima
    Can't hold 4psi? what type of terrible clutch did u get?
    also, if you needed to take out fuel at idle then it probably isn't holding stock pressure anymore.
    reason i ask is i need to put in my 450, but once you fix something something else pops up.
  15. #90
    Apr 2006
    Minnesota eh?
    86 325es
    Should probably just take the 255 out, your just blowing through it anyway.
  16. #91
    Frederick, MD
    It has held 20-25psi on and off for 8 years. Switched to e85 and was adding boost again ~17psi and then the slippage occurred. Think it was just its time (Sound bend stage 3 used for 285 bucks )
    Isnt that the truth Let me get a gauge on it and see what its doing. I did the dual power feeds to the fuel pump and the voltage drop is definitely a real thing. Could easily hear the difference in pitch from one wire, to two wires. Grounds didn't seem to make a difference, as it grounds mostly from the contact between the fuel top hat and the tank.
    Eh, i slightly disagree. Pumps in series are able to handle additional head. IE small ass oem fuel lines and allow for additional flow.
    Yes it may not be as efficient. I will be interested to see how it is at full power again. I hit about 108% duty cycle doing some testing with only the 255, (e65, 6 degrees more timing, 108% was a peak not consistent)
    Just ordered two 150psi pressure sensors. Looks like the connector is very similar to AEM, so good to know i can always swap out for good ones if these are bad. One for fuel inlet pressure, one for fuel outlet pressure. That way we can get all the data
    Step five enjoy
  17. #92
    Frederick, MD
    Answer is in. With the 450 and 255 running i get 45 psi during priming. Once it starts up or rests. i hold 40psi spot on at idle. I have not driven it yet, as i need to make a more drive-able solution for 5v input.
    fuel return and fuel supply hard lines look similar in size FYI.
    during priming i saw 5 psi of pressure right behind the regulator. Both during idle and priming. Of course once the pumps turns off it goes to 0.
    FYI, cheap pressure sensors work. just make sure you install on the right line
    Suspension Related:
    Has anyone ran into to the rear end adjustment bolts/nuts coming loose? This is the 5 or 6th time i gotta tighten the right most adjuster.
    Step five enjoy
  18. #93
    Frederick, MD
    Pull against a 2012 STI, rebuilt engine, stock turbo and tune.
    https://www.youtube.com/watch?v=41GSiXVFDGw
    Ignore the burble tune, was screwing around with that and seeing how it sounded from the rear
    Step five enjoy
  19. #94
    Frederick, MD
    New clutch arrives today. Ordered Monday, def not ready for it was trying to have everything prepped for it to go right in. May be a late night tonight
    Also need to add the final brackets on the exhaust.
    Once the clutch is in ill be pulling the front body parts and begin prep and paint.
    Step five enjoy
  20. #95
    Frederick, MD
    Clutch is in, went through a hiccup with a damaged second disk. Returned, then purchased a new one. Test drives tonight
    Attachment 653305Attachment 653306
    I have no idea why these photos randomly rotate.
    Step five enjoy
  21. #96
    FL
    are slow.
    DKM is a solid kit, popular in the N54 crowd.
    I did the IS head swap on my old 325e and I still remember how much faster the car was compared to the low revving e motor. I think 4500rpm redline? That little 2.7 na was a champ in the E30. A turbo 2.7 must be a blast. Enjoying the build thread, thanks for sharing!
    -Dr. Seuss
  22. #97
    Frederick, MD
    Thanks Hova, do you recall how they are breaking in the clutch? I’ve been doing around the area very light pulls. Letting it warm up then cool down. It’s getting better for sure as I put the miles on.
  23. #98
    Jul 2005
    California
    Bima
    what material is it?
  24. #99
    Frederick, MD
    Appears to be organic type.
  25. #100
    Frederick, MD
    Put about 160 miles on it this weekend. So far i like it and grabs very well. Have not turned the boost up yet but plan on scheduling dyno time in the upcoming week or two.
    I want to log fuel pressure so it may get delayed until then.
    Currently up around E72-E74. I need to check the logs to see how the fuel system looks.
    Step five enjoy
  1. Castro Motorsport: S50 Turbo E30 Race Car Build!
    By e30polak in forum Forced Induction
    Last Post: 11-22-2013, 01:52 PM
  2. Castro Motorsport: S50 Turbo E30 Race Car Build!
    By e30polak in forum BMW Rides & Events
    Last Post: 10-18-2013, 04:23 PM
  3. E30 ultimate e30 street car - turbo'd s52
    By multiplex in forum 3 series & Z Series
    Last Post: 03-08-2012, 11:54 AM
  4. E30 E30 Turbo E30 GRM Challenge Car for sale in TN
    By BimmerFreak in forum 3 series & Z Series
    Last Post: 09-07-2011, 03:04 PM
  5. E30 Turbo E30 GRM Challenge Car for sale
    By cheechthechi in forum Race Cars & Track Parts
    Last Post: 09-06-2011, 12:53 PM
