Results 1 to 12 of 12
Thread: Ews-dme sync code
    Aug 2017
    danmark
    E46 318i
    Ews-dme sync code
    I had disabled all the keys with pa soft.. now i have connected the pin 4 to pin 8 and erased the ews3.
    I have backed it up and All that Stuff but the backup didnt saved the ews-dme resync code
    So now after i have coded New keys with ak90 i cannot resync ews to dme Because of the isn number in ews is FFFF and in dme its Another..
    So all i have is inpa, inpa cable ista, ak90 and bmw scanner 1.4.0
    So the question is how do i read the isn number from dme to resync ews with dme. Car dosent start or crank
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Moved from General BMW sub-forum.
    88M3 AW 43k miles Project FS
    Jul 2004
    Houston, TX
    36 Cylinders
    What car, what dme/dde? That's the most important part. There are so many ecu types and each requires a specific method, if there even is one.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Aug 2017
    danmark
    E46 318i
    E46 318i n42b20 facelift dme ME9.2 / EK924
    Jul 2004
    Houston, TX
    36 Cylinders
    You have to rebuild the ISN in the EWS. Original ISN is probably lost. Send me a PM with your email, and I can try to help with some, when I have time. But you may also need to do a BDM read of your dme now.
    Do you have all your current key data saved? Actually it should not be a problem if you have ak90.
    -Abel
    Aug 2017
    danmark
    E46 318i
    Sep 2017
    Tampa
    2008 135i
    Did you figure it out? I'm getting a cas code because I got a used DME. Wording if you can align the ews to the used DME.
    Jul 2004
    Houston, TX
    36 Cylinders
    His DME, EWS, and car is completely different than your car (135i). He solved it by reading the ISN from the ME9.2 dme with a bdm read. Completely different than your situation.
    Why are you changing your DME? Your particular DME (MSD80 or MSD81) and CAS requires some expensive aftermarket tools to link up. It has very difficult security built in.
    Do you still have the old DME?
    -Abel
    Sep 2017
    Tampa
    2008 135i
    Yes I have my original DME msd80
    Sep 2017
    Tampa
    2008 135i
    Because my mosfets got fired I had it repaired but that did not work
    Dec 2012
    North Carolina
    2009 335i M-Sport Coupe
    Quote Originally Posted by Fallen Leaf View Post
    Unless someone on here has Autohex II, you'll want to contact G coding BMW. His number is (985) 492-0666.
    He has the tools to sync a used MSD80/MSD81 with your CAS module.
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by RocketSurgeon View Post
    There are other ways too
    -Abel
  1. EWS - DME Sync. E36 MS41
    By v2x in forum Diagnostic Software
    Last Post: 12-09-2018, 01:59 PM
  2. 750i EWS DME/DME2 Sync issues
    By Hemidog in forum 1995 - 2001 (E38)
    Last Post: 04-20-2014, 07:47 AM
  3. Carsoft EWS-DME sync?
    By LeonH in forum Diagnostic Software
    Last Post: 07-26-2012, 03:54 AM
  4. DME/EWS and key coding.
    By anncam in forum 1995 - 2001 (E38)
    Last Post: 02-02-2010, 01:04 PM
  5. Stock DME - Syncing EWS?
    By TWRViper in forum 1991 - 1999 (E36)
    Last Post: 09-09-2008, 06:50 PM
