Results 1 to 6 of 6
Thread: Powder coating Zionsville Fan Shroud
    Lake Oswego, Oregon
    2001 BMW 740i Sport
    Since all the parts in the engine bay are black, and the Zionsville fan shroud is silver, I am looking to powder coat the fan shroud black. I want to keep the engine bay looking as OEM as possible. Would powder coating be the best option (under the intense heat in the engine bay) for the fan shroud? Any thoughts?
    Alachua, FL
    '92 BMW 535i/5 Lazurblua
    I would think Hi temp paint would be just as good. Just look at the temperature rating. It should be rated for 300+ degrees.
    Sent from my Z956 using Tapatalk
    lA, ca, lA
    BLK 01 sp, 20 Trail Boss
    I was going to do this with mine just haven't got around to it yet, no paint or powder coating required to keep the OEM look.
    http://bimmerboard.com/forums/posts/565773
    Greenville, SC
    01 749iM/6 sporty
    I powdercoated my Zionsville coolant bottle and painted the shroud and the side tanks of the radiator with wrinkle black. It's been over 3 years and all is fine.
    Trevor
    01 749i sporty, build 12/00 "Sports Barge",S62
    92 VW Corrado VR6,AAA
    81 Delorean,B28F
    81 VW Rabbit Pickup 1.8T,AWW
    03 VW Passat wagon 4.0 W8 6spd
    Feb 2013
    The Motor City
    1997 750 IL
    Any engine paint can handle the heat but will not stick to the shroud for crap unless you media blast it first. Sending it to be powder coated is def. the toughest finish.
    ---- Processing Individual ----
    Z1XX Upholstery
    Seats front and back in Epingle / leather englishgruen,
    As Schl.Nr. B9EG.
    Front seat backrest in Montana Englishgruen (No. 8 174 861)
    Other interior equipment as for Volleder Nappa englischgruen,
    Schl.Nr. P5EG
    Lake Oswego, Oregon
    2001 BMW 740i Sport
    Yeah I am researching different powder coating companies in the Portland area to do the job. I would rather spend the extra money and do it right the first time, without having to worry about it later on.
  1. E36 Zionsville Aluminum Fan Shroud & Expansion Tank
    By Ronin951 in forum Engines, Performance Parts & Software
    Last Post: 08-01-2015, 08:06 AM
  2. FS: Zionsville Aluminum Fan Shroud with Aluminum Expansion Tank & Cap
    By n0n0perational in forum Engines, Performance Parts & Software
    Last Post: 01-27-2015, 10:21 AM
  3. Zionsville Autosport - Fan Shroud
    By Jamos in forum 1995 - 2001 (E38)
    Last Post: 10-24-2013, 09:24 PM
  4. Zionsville rad + stock fan shroud?
    By Ritt in forum 1992 - 1999 M3 (E36)
    Last Post: 07-10-2010, 09:09 PM
  5. E39 Zionsville fan shroud new in box $200
    By chucksrt in forum Engines, Performance Parts & Software
    Last Post: 07-01-2010, 02:35 PM
