Does anyone have one of the following wheel hubs in their possession that I may be able to get some measurements.
E28 any
E34
E46 m3
E38 740
I am doing a front brake upgrade on my e36 and need to space my hub out. I am thinking different models may have a different offset. I have already found out that the listed models have different aftermarket part numbers and all have 37mm (from memory) I.D. bearing races. Any info would be greatly appreciated 🤞
Sent from my SM-G930F using Tapatalk
Free bump because this would be good info to have, but I have no info for you
I have an E34 530iT hub I can measure. What are you looking for exactly?
Im not sure this is going to be useful, but ive heard e36 m3 calipers are the same as e34 m5 calipers in the front.
Herr, wirf Hirn vom Himmel! ... oder Steine, Hauptsache er trifft.
88 Alpineweiss / black E30 M3 -Project.
Brilliantrot / black US SPEC 3/90 prod e34 M30b35 535i 5spd - Modded.
98.5 Tiag Silber /black e36 m3 - Modded.
99.5 Estoril Blau /dove e36 m3 - Modded.
07 Crimsonrot /black E83 X3 6spd - Stock..
Wmrcs, if you place the hub with the abs ring closest to the desk and take a ruler and measure to the upper side of the flange the rotor mounts to it should give me enough information. Thanks
Hello!
What front wheel bearing brands are fairly good for our HD61 525i?
