Results 1 to 7 of 7
Thread: What could engine damage be from misfire due to oil in spark plugs
    Dec 2005
    RI
    2000 750iL
    Looking at a 2001 V8, which despite being on this forum for over 10 years, i know little about. I did pick one up several years back to part out that had severe engine damage from failed timing chain guides. Wow what a mess. I thought it may have been salvageable until I found metal shavings in the oil filter. Anyway....
    Haven't actually gone to see it yet. owner states needs engine work. He said oil leaked into spark plug valleys causing misfires. he changed the vcgs but the "damage was done". What damage could that have caused? What might I actually want to check when i go see it?
    I asked if it were driveable. he said it moves but wouldn't drive it long distance.
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Never seen it do anything other than, eventually, foul the plugs. I wonder if something else is going on, i.e. ccv membrane bad causing smoke that he attributes to the oil in plug ports.
    Apr 2003
    Seal Beach, Ca.
    2003 540s, 2000 740s
    Yes, oil can collect in the spark plug holes if the valve covers are leaking.
    However, maybe I'm missing something here, but do people think that oil leaks down the spark plug washer, thru the spark plug threads & ends up inside the combustion chamber? Wouldn't that slight amount of oil (if it made it that far) just be burned off when the plug fires?
    <== Steptronic Sealbeach740
    2000 740i sport: 74k Green/Tan chrome MPars, clear corners, quad brake lights, AIC hi-beams, Hoen fogs, 16x9 screen, MKIV, TFT LCD screen in back, license plate backup camera with "on demand" switch, iPod audio/video (CDC/iPod audio switching, iPod video on 16x9 screen), Basslink, gauge rings, ///M pedals, switched steptronic +/- shifting mode, E46 paddle shifter steering wheel, Dinan engine & tranny software upgrade, DDEs controlled via Euro fog light switch, painted calipers with "BMW" lettering, windows up/sunroof close via remote.
    2003 540i sport: 81k, Sterling grey/grey, MKIV Nav, PDC & CWP - Added license plate backup camera with "on demand" switch, paddle shift steering wheel, windows up/sunroof close via remote, Akebono's, painted calipers with "BMW" lettering, quad brake lights, iPod audio via AUX mode/video via 16x9 screen, BMW TV tuner, ///M pedals & gauge rings.
    Jul 2016
    Chicago, Illinois
    are slow
    Metal shavings in the oil filter meant nothing, that's just the chain wearing down on the backplate of the guides.
    Anyways for the 01, probably just a fouled plug.
    Feb 2013
    The Motor City
    1997 750 IL
    Possible cat damage over the long term maybe with misfires and fuel making it to the cats I thought I read that fuel can pool in them then detonate and put excess pressure on the cats.
    ---- Processing Individual ----
    Z1XX Upholstery
    Seats front and back in Epingle / leather englishgruen,
    As Schl.Nr. B9EG.
    Front seat backrest in Montana Englishgruen (No. 8 174 861)
    Other interior equipment as for Volleder Nappa englischgruen,
    Schl.Nr. P5EG
    Dec 2005
    RI
    2000 750iL
    Metal shavings everywhere once i started tearing into the car for parts. the car was in pretty poor condition overall so wasn't worth saving.
    For this car, i'm trying to figure out what else is up. He didn't say it was smoking so don't think it was the ccv. If a plug were fouled I would hope he cleaned out the oil while doing the gaskets. And for the cats, the V12 will shut off fuel to the skipping cylinder as a self preservation measure. Sometimes to the whole bank. Do the V8s have that feature?
    I'm wondering if it might be completely unrelated to the oil leak. Like the stories of unplugging the MAF and driving away... Or maybe a coil or two making the engine run rough.
    Hope to check it out this coming weekend.
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Quote Originally Posted by RIboater View Post
    Yes.
  1. Oil in Spark Plug Wells = Bad Engine Problems?
    By ken.mark in forum 1991 - 1999 (E36)
    Last Post: 10-20-2011, 11:23 PM
  2. What could this sound be?
    By Danny318 in forum 1991 - 1999 (E36)
    Last Post: 10-08-2007, 11:47 PM
  3. What could the problem be?
    By Andryuha in forum 1988 - 1996 (E34)
    Last Post: 05-02-2006, 05:11 PM
  4. Burning odor, what could it potentially be?
    By Jean-Claude in forum 1992 - 1999 M3 (E36)
    Last Post: 01-20-2006, 02:23 AM
  5. What could the problem be?
    By quickslvr387 in forum 1991 - 1999 (E36)
    Last Post: 10-08-2003, 08:25 AM
