Results 1 to 3 of 3
Thread: E38-resurrection 88 degree thermostat question
    Feb 2013
    Brisbane, Queensland, AUS
    '89 535i, '00 735i sport
    Hi all, could someone give a brief summary of the idea of the 88 degree thermostat ? I understand that it lets the car run cooler but I've been reading and now understand that the M62 is a map controlled thermostat that is supposed to open/close the thermostat depending on load to improve efficiency and emissions?? Does this then mean that if you use an 88 degree thermostat you don't connect the plug? There was also mention of a heating element that is affected in some way.
    thanks
    john
    West Plains, MO
    '97 540i Dinan, 98 740iL
    The heating element you mention is inside the stock thermostat and is how the ECU controls it. By sending current to the heater, the thermostat opens at a lower engine temp than the super-hot 108C cruise temps.
    I bought the lower temp stat (for a diesel IIRC) from Schmiedmann.com but haven't installed it yet. This one does not have the heater, therefore no plug. There will be an error code stored (Thermostat Final Stage) with it disconnected, although it doesn't light the Check Engine light. Some people hook up a hefty power resistor to the harness to eliminate this code, but I don't think anything else is affected except the hidden code.
    '98 740iL E38 201k, TCG at 190k, 5HP24 at 195k
    '97 540i/6 E39 Dinan blower & stage 1 suspension 114k
    '93 525i E34 "Golf Ball" (hail damaged) 334k
    Jan 2017
    North Carolina coast
    2001 740iL Prod 4/2000
    The DME control of the stock thermostat heating element occurs at full or WOT power to allow greater flow to offset the increased heat during those conditions.
    Installing an 88c thermostat promotes cooler running all through the power range, hence no need for DMW controlled heater-assisted opening. The reduced temperatures
    via the 88c unit produces less pressure in the cooling system overall, reducing stress on radiator, hoses, heater core, trans, engine components, etc etc while causing no detrimental effects
    on power or fuel economy.
    Less heat under the hood, better for all the stuff under there. Leave the heater plug disconnected and taped up, good to go.
  1. 80 or 88 degree thermostat?
    By cohny in forum 1992 - 1999 M3 (E36)
    Last Post: 01-06-2017, 05:41 PM
  2. Brand new 88 degree thermostat E36
    By shift.shape in forum Engines, Performance Parts & Software
    Last Post: 02-27-2007, 07:23 PM
  3. 88 degree thermostat
    By dieseldriver99 in forum 1991 - 1999 (E36)
    Last Post: 11-30-2006, 02:01 PM
  4. E36 M3 76 degree thermostat question
    By Earthman03 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-19-2006, 02:37 PM
  5. 75 degree or 88 degree thermostat
    By EUROCLIQUE in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-02-2005, 10:08 PM
