I know this isn't the for sale section bud I'd really like to see if anyone has one they could part with before I buy new and have a two month wait for a driveshaft. If anyone has one PWWWEAASSSEEE LMK.
The drag racing monkey has got you. Next thing you know, you'll be ls swapping shit and talking about torque converters and trans brakes and things
328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
9.20 at 150 on 22psi
Lmao yeah it's all downhill from here.
Your better off doing heroin, that way you may actually end up with some money at the end
I get drug tested for school or I would.
Having that 10 second slip tho.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Nobody ?
I would try Butters for the DSS. I have bought 3 from him (for 4 bolt 188, then 6 bolt 210, then 6 bolt 210 with foam filling to reduce singing). You could make your own 210 adapter if you like cutting and welding, but buying one from CES or RallyRoad would be easier.
Anyone have either of these things???
Yeah I have spoken with butters. I really don't wanna wait 8 weeks for a drive shaft. We are coming up on perfect boost weather in another month or so.
I'll call tomorrow, they may have one pre made that I ordered a bit ago.
I'll text him now.
1996 332IS
Built 3.2
Still looking!
I have a whole 8 second package rotting in the garage for you
Rotting? Strap it on a pallet. Send it my way. I'll even pay shipping XD
Yea save urself the trouble and buy my entire car for 18k
I'd sell my car for $18k as well, even though it is only worth about $10k.
1996 332IS
Built 3.2
Still need a DS and the conversion kit if anyone has either.
How about a C4 bellhousing conversion, complete with torque converter, and a driveshaft with 6bolt adapter and you can keep the 188mm lsd. You only need to supply a trans.
Don't wanna give up the manual trans. Someone has to have a DSS ds they don't want..
Why does nobody love me
They loves you at the truck stop. Go get yourself a fist full of $5 bills.
That's the easy part. The hard part is exchanging those $5s for a driveshaft.
Butters will help you with that. Just get a $100 driveshaft in the meantime so you can drive it.
Yeah I'm looking for a stock 6 bolt driveshaft now.. but no body seems to have one of those eithet.
