Results 1 to 6 of 6
Thread: New Meyle Steering idler arm bushing seems a little loose
    Aug 2017
    Dublin, Ireland
    2000 BMW 7 series
    Hi
    Just replaced the steering idler arm bushing (Meyle 3003221101) in my E38 - I had great difficulty extracting the old one as it's an interference fit and 17 years old etc. I expected that it would take time and patience to fit the new one into the steering arm, however it just slid in. It's not wobbling about or anything but it's certainly not an interference fit. Is this normal or have I a problem? Paul
    Dec 2011
    Lancaster CA
    e34,e38,e39,e46,e70,e90
    Quote Originally Posted by Paulgallagher View Post
    Hi
    Its not a problem. Thats the way they fit. As long as you torqued it correctly it will be fine. Remember, the old one was there for years and dirt, heat etc cause the metal pieces to form a bond, which you must struggle to break when you remove. Install is easy.
    Aug 2017
    Dublin, Ireland
    2000 BMW 7 series
    Many thanks for your reply - my mind is now at ease
    Aug 2017
    Dublin
    E38
    Just an update - I completed the install and torqued correctly. When I move the roadwheel from side to side (easier while car is jacked up) the idler arm moves up and down the bushing. It system obviously needs the interference fit to be stable. I intend ordering a complete unit so there will be no doubt. If any has a comment I'd welcome it.
    Aug 2017
    Dublin
    E38
    Aug 2017
    Dublin
    E38
    This is a video of the idler arm and bushing play - no interference fit
  1. ***Brand New*** E36/E46 Meyle Rear Trailing Arm Bushings
    By Slvr328IS in forum Suspensions, Springs & Shocks
    Last Post: 02-09-2015, 03:04 PM
  2. FS E46 Meyle HD control Arm Bushings NEW!!
    By tc5953 in forum 3 series & Z Series
    Last Post: 04-02-2013, 05:39 PM
  3. FS: *NEW* UUC delrin clutch arm bushing, brake light circuit switch (4 ping)
    By wimpwgn in forum Exterior Lighting & Body Parts
    Last Post: 03-28-2007, 02:51 AM
  4. FS: Brand new E30 urethane control arm bushings from BMP Design
    By Bimmerobsession in forum BMW Parts For Sale
    Last Post: 09-11-2006, 10:31 PM
  5. FS - Brand New E30 Rear Trailing Arm Bushings (2 pair)
    By custom32 in forum BMW Parts For Sale
    Last Post: 02-13-2006, 07:57 AM
