Results 1 to 6 of 6
Thread: Coolant flush question
    Aug 2017
    Dothan. AL
    2011 BMW 328i Sedan
    Question Coolant flush question
    I'm getting ready to do my own coolant flush(including engine block). After watching several videos and reading numerous "How to's" I'm a bit confused. Emptying and refilling is not exactly a flush. That's just a change.
    One article advised emptying the system and then refilling with distilled water, bringing the car up to operating temp, then repeating the process but filling the final time with coolant. Since I found green sh*# in my expansion tank, this sounds like a good idea. I want that crap out of my car!
    Any thoughts, words of wisdom, suggestions?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Definitely perform a true flush by fully draining the cooling system, including the block via the block drain. You'll likely get drenched with coolant when you remove the block drain! Fill with distilled water and properly bleed the cooling system. Get the engine up to full temperature and allow it cool a bit. Drain and fill with a 50/50 mix of BMW coolant and distilled water. If you're really anxious you could add a gallon of vinegar to the distilled water fill. But, I recommend doing a distilled water flush after that flush.
    Aug 2017
    Dothan. AL
    2011 BMW 328i Sedan
    The vinegar sounds like a great idea! Thanks for that tip. So, I'll need approximately 9 gallons of distilled water. 3 gallons DW + 1 gallon vinegar for the initial flush. 4 gallons for the second flush, and 2 gallons to mix with the 2 gallons of BMW coolant. Does that sound right?
    Also, I need to do the bleed with the key engaged, heater temp at 91 and fan on low, right? No need to press the accelerator for ten seconds and then leave it engaged for 12 minutes? That's for a different model, correct?
    Aug 2017
    Dothan. AL
    2011 BMW 328i Sedan
    Dumber question...what do I do with all of this used coolant and flush water? Can I drop it at the auto parts store?
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    Jiffy lube will take it.
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    Quote Originally Posted by BamaBMWgirl View Post
    Thats for the e9x chassis. The e46 are more old school.
    With the car on level ground or the front slightly raised, remove bleed screw and fill the expansion tank until you have coolant coming out the bleed screw hole(it will be slow as you get near). After that close everything up and go for a drive with the heat on full blast. Drive for long enough to get the car up to temp (10 min is usually enough). After that let the car cool down for a few hours and then recheck and adjust your coolant level based on the stick in the expansion tank, Typically it will be very close to perfect, but the odd time you may have to add a little.
    If your only concern is some green coolant in the system full flushing is unnecessary. Just fully drain the system from the rad and block drains, then fill with fresh blue mix. The green left will be so diluted it wont be detectable. Most green coolant you will find on the shelf today is aluminum safe anyways.
    Current:
    - 09 335i MSport, FBO.
    - 98 Euro M3, Estoril Blue
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, Black on Black, Full Leather.
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
  1. Coolant Flush Question
    By darrtracing in forum 1992 - 1999 M3 (E36)
    Last Post: 01-28-2008, 09:07 PM
  2. Coolant flush question?
    By manm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-02-2006, 06:02 PM
  3. Quick coolant flush question (e39 540)
    By NickAD in forum 1996 - 2003 (E39)
    Last Post: 05-20-2006, 04:14 PM
  4. Possibly dumb coolant flush question...
    By tbreihan in forum 1991 - 1999 (E36)
    Last Post: 05-20-2005, 04:26 AM
  5. Quick Coolant flush question - In the middle of flush.
    By JClark in forum 1992 - 1999 M3 (E36)
    Last Post: 11-03-2004, 09:27 AM
