Results 1 to 15 of 15
Thread: Rough idle at start up
    Feb 2014
    allentown
    99 Z3MC/00' 2.8 roady
    S52 runs a little rough when I start it up. But runs smooth when she warms up. Anyone have an idea of what part is going bad?
    Oct 2003
    Seattle
    99 M3
    Plugs and spark plug/coil extenders, how old are they? Pre-catalytic convert O2 sensors are a 100k service item.
    Any stored codes?
    Terry F.'s Avatar
    Terry F. is offline ONLY BMW Content is + Moderator
    Broward County, FL
    M-Roadster
    No codes? Do you service it at all? Anything due, filters, etc?
    Stuff. I got stuff.
    Feb 2014
    allentown
    No codes and all tuneup parts have less then 4K. Vanos rebuilt with less then 1K
    Terry F.'s Avatar
    Broward County, FL
    M-Roadster
    Air pump crap all good?
    How long until it clears up? Seconds? Minutes?
    Stuff. I got stuff.
    Feb 2014
    allentown
    As far as I know it's all good. I just found this old thread. So I'll clean the ICV with carb cleaner and see how it goes.
    Terry F.'s Avatar
    Broward County, FL
    M-Roadster
    Is that your next step?
    Stuff. I got stuff.
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    Terry is on the right track. If the roughness is for less than a minute, you have a small vacuum leak. When the SAI system runs, it jacks the mixture as rich as it dares. When you add positive fuel trims from a leak, it gets arich lopey-hunt until the pump shuts off.
    /.randy
    Terry F.'s Avatar
    Broward County, FL
    M-Roadster
    You are in better hands now.
    Stuff. I got stuff.
    Feb 2014
    allentown
    The roughness is for a couple of minutes until the car is warmed up. If the air pump system would be leaking is that part of the evap system? Also would I throw a code then, because I don't have any codes.
    Dec 2007
    Great Dismal Swamp
    If it goes on for more than 30 seconds or so, then look to the ignition system. Also check the fuel trims with an OBDii scanner. Just because there isn't a code doesn't mean they are fine. For example, a P1188/89 code sets at 10.3%. You could be 10.0%... same running problem, but no code.
    /.randy
    Feb 2014
    allentown
    Ok thanks, I'll have to have my buddy use his scanner
    Jul 2017
    Miami
    1997 Z3 2.8 convertible
    Hey Red, Did you ever clean that ICV?? If so how did it run after that??? and how hard was it to get at that valve.
    I am asking because I have the same issue
    Dec 2007
    Great Dismal Swamp
    On these engines (the M54 is a totally different animal), the IAC valve can not cause rough running. If it sticks, the idle speed will be wrong. And if it sticks, you need to figure out why. The usual cause is those crap aftermarket air filters.
    While we're on the subject of fake internet lore. O2 sensors do not just wear out. They are murdered. The ceramic heater can be broken by shock. The sensor itself can be contaminated. But they don't just die at xxxK miles. The most common cause of failure is the same as what kills cats; contamination from engine oil, antifreeze or unauthorized fuel additives. I don't know who started the 100K mile thing, likely someone selling O2 sensors. It's not true.
    /.randy
    Feb 2014
    allentown
    I just finished up cleaning the ICV and NOW I have high idle, which I didn't before. The ICV didn't rattle inside before cleaning and now after cleaning the part inside moves back and forth quite nicely. Also seems to run smoother. Wish I would have know to clean it when I had everything torn apart a couple of months ago. But it only took 1hr.
  1. Rough idle at start up and stop?
    By ZFawbs93 in forum 1991 - 1999 (E36)
    Last Post: 06-10-2014, 01:06 PM
  2. Rough Idle At Start Up
    By bstrauss132 in forum 1991 - 1999 (E36)
    Last Post: 05-03-2011, 08:46 AM
  3. Rough Idle at Start-up
    By dhinez in forum 1991 - 1999 (E36)
    Last Post: 01-20-2010, 04:51 PM
  4. 2000 BMW 528i :Rough idle at start up
    By illwill4781 in forum 1996 - 2003 (E39)
    Last Post: 10-15-2009, 03:41 AM
  5. Rough Idle at Start-up
    By PhoenixBMW in forum 1995 - 2001 (E38)
    Last Post: 10-29-2008, 08:37 PM
