Results 1 to 6 of 6
Thread: Smoke when ac is turned on
    Aug 2017
    Utah
    E46 330ci
    Every time I go to turn on my air conditioning on my 2002 330ci, a couple minutes later it starts to smoke. I wanted to see if anyone else was having this problem and if they had a fix or could at least diagnose my problem, Thank you.
    Dec 2013
    Chicagoland area
    EXOTICS
    Where is the smoke emitting from, specifically?
    Aug 2017
    Utah
    E46 330ci
    Next to the postive terminal under the hood.
    Dec 2013
    Chicagoland area
    EXOTICS
    I would have to be there to try and diagnose, to many variables.
    Have a trusted mechanic examine, give their diagnosis and estimate,
    then post back with results.
    Jan 2016
    Honolulu,Hawaii,USA
    2004 BMW 325i
    I have a similar smoking problem and thought it was my valve cover gasket, so I replaced it and still having the same thing happen after a few minutes of turning on the engine.
    Nov 2011
    trowbridge,wiltshire,UK
    Make sure it is "smoke". if the interior of the car is warm and humid, cold air from the AC unit can cause condensation - fog - which looks like white smoke. (that is inside the veihcle)
    Under the hood, you can get the same effect if there is a high pressure leak in that area. what colour is it and does it smell?
  1. Engine overheats when AC is turned on
    By Zippylock in forum 1991 - 1999 (E36)
    Last Post: 08-11-2012, 01:40 AM
  2. Car vibrates at idle but vubrations stops when AC is turned on...why!?!?!
    By kathybmw in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-05-2012, 05:27 PM
  3. Loud Fan noise when AC is turned on
    By tavo80816 in forum 1995 - 2001 (E38)
    Last Post: 06-24-2010, 11:43 AM
  4. smoke from under the hood when heater is turned on
    By fangtl in forum 1991 - 1999 (E36)
    Last Post: 10-15-2007, 12:02 PM
  5. Smoke when AC is on ... Weird
    By iToast in forum 1996 - 2003 (E39)
    Last Post: 06-19-2007, 10:52 PM
