Page 2 of 2 FirstFirst 12
Results 26 to 40 of 40
Thread: My "New" 1983 BMW 633CSI
  1. #26
    Jul 2016
    Madison, Alabama
    2012 BMW 528i (sold)
    Quote Originally Posted by Shipper View Post
    Lovely looking car. Congratulations. At $1.5k that is a real bargain.
    Thank you sir! I'm slowly but surely trying to get it back to its glory days.
    2021 BMW X5
    2019 BMW 330i
    2009 BMW 128i
    2001 BMW 740il
    1983 BMW 633CSI (Sold)
    2016 BMW 528i M-Sport
    2012 BMW 528i (Sold)
    2008 BMW 328i (Sold)
    2003 BMW 330xi (Sold)
  2. #27
    Jul 2016
    Madison, Alabama
    Does anyone know how to easily remove the 3rd brake light cover and the size bulb I will need?
    2021 BMW X5
    2019 BMW 330i
    2009 BMW 128i
    2001 BMW 740il
  3. #28
    Sep 2014
    asheville, nc
    89 635CSi & 87 MB 560SL
    Sean,
    From the rear seat pull the black part of the light upward on an angle (about 30 degrees) toward the roof and it should slide forward. I would use a Honda,
    Stanley bulb 34903-SF1-A01, purchase the bulb from a Honda dealer, third party bulbs are junk. I replaced all the brake bulbs with the Honda, they are brighter.
  4. #29
    Jul 2016
    Madison, Alabama
    Quote Originally Posted by roger hanley View Post
    Sean,
    Thanks for this info! I will switch out the bulb at the beginning of the week.
    2021 BMW X5
    2019 BMW 330i
    2009 BMW 128i
    2001 BMW 740il
  5. #30
    Jul 2016
    Madison, Alabama
    Is there a DIY fix for the windshield wipers? The motor for them seems to have gone out.
  6. #31
    Sep 2016
    North Florida
    1983 633csi, 2017 540i
    Is there power to the motor? If so, the motor could just be bound up with old caked up grease inside the gearbox. Mine was.
  7. #32
    Feb 2009
    Pittsburgh, PA
    '86 635CSi, '08 128i
    I had a similar problem with my wipers, the passenger side pivot bearing in the wiper transmission had seized up. The wiper motor is fairly easy to remove, but I had to take the whole cowling apart to remove the transmission & arms. Once I got it out it was pretty easy to service. I also cleaned up the motor's contact wheel and lubed the pivots with white lithium grease. Worked great after that!
    There's also a timer relay that controls the wipers in some E24. Check it out, it's the long black one at the back of the fuse box.
  8. #33
    Jul 2016
    Madison, Alabama
    Hey fellas. Where exactly is the wiper motor located?
  9. #34
    Nov 2005
    Brookfield,CT
    '92 325IC '88 635
    Quote Originally Posted by Sean2005 View Post
    Here: wiper motor.JPG
    '88 635, '92 325IC
  10. #35
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    Have a known working motor.
    81 Euro undergoing total nut and bolt restoration
    pictures at: flickr.com/photos/bertsphotos
  11. #36
    Jul 2016
    Madison, Alabama
    Quote Originally Posted by carsnplanes View Post
    Thanks!
    2021 BMW X5
    2019 BMW 330i
    2009 BMW 128i
    2001 BMW 740il
  12. #37
    Jul 2016
    Madison, Alabama
    Its been awhile since I visited this thread. I'm really enjoying the car. I may have a small oil leak. When replacing the valve/head gaskets, what else do you all recommend I replace? I was thinking I should go ahead and replace the water pump and timing chain.
    2021 BMW X5
    2019 BMW 330i
    2009 BMW 128i
    2001 BMW 740il
  13. #38
    tvjake2's Avatar
    tvjake2 is offline SoCalEights - CA BMW CCA Member
    Oct 2012
    Glendale, CA
    '97 840Ci, 1980 308
    Unless your chain is really noisy, I wouldn't worry about it. If it hasn't been done I'd suggest your next focus be the undercarriage. Lots of bushings and stuff under there that can wear out. Inspect the motor and transmission mounts, test the shocks, idler arm, etc. All that goes to steering and handling.
  14. #39
    Jul 2016
    Madison, Alabama
    Quote Originally Posted by tvjake2 View Post
    Thank you for responding. The chain is not noisy at all. The undercarriage seems to be in good condition. The previous owner seemed to have tackled that area. The car handles great at high speeds. After I replace the gaskets, I'm going to focus on the exhaust because I'm hearing a rattling noise. I believe I still have the original exhaust set up still. I know OEM is the way to go but does anyone have any suggestions?
    2021 BMW X5
    2019 BMW 330i
    2009 BMW 128i
    2001 BMW 740il
  15. #40
    Feb 2009
    Pittsburgh, PA
    Exhaust rattling could just be a loose heat shield. There's an aluminum sheet fastened to the underside of the transmission tunnel, sometimes it gets a little worn out. It can pull away from the mounting studs, then it can rub on the driveshaft or fall onto the exhaust. It's pretty easy to put a new fender washer onto the original nut & stud to repair.
    The front hangar can also rust out and rattle. It's bolted to the rear of the transmission. I usually end up removing it.
    If it's the catalyst or a rusted muffler, I've had trouble finding reasonably-priced OEM exhaust parts. They're well made but very expensive. I've been very tempted to have an exhaust welded up instead at a muffler shop.
  1. 1983 BMW 633csi 1700obo!
    By moving3e in forum 1976 - 1989 (E24)
    Last Post: 04-01-2010, 12:32 PM
  2. ~1983 BMW 633CSi Alpinweiss, 3k.~
    By Speede7 in forum 5 series & 6 series
    Last Post: 05-28-2008, 12:44 AM
  3. FS: 1983 BMW 633CSi 5sp black/black - $2,800 ORO - Tucson, AZ
    By e24pilot in forum 5 series & 6 series
    Last Post: 04-01-2008, 03:10 AM
  4. Just got my nice new quote for repair...:s
    By eonone in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-22-2006, 03:59 PM
  5. FS: 1983 BMW 633CSi Black/Black 5sp
    By e24pilot in forum BMW Cars For Sale / Wanted
    Last Post: 08-20-2004, 04:29 AM
