Results 1 to 12 of 12
Thread: Help with transmission and options for replacements
    Sep 2016
    Orlando, fl
    1992 BMW 850i V12
    I have a 1992 BMW 850i M70 4hp24 automatic
    I think my forward/reverse drum broke. I put it in reverse and started backing up then all the sudden it bucked and seemed like it went into park. Then i put it in D and car started making grinding noise until it switched to 2nd. After 2nd and up it runs fine but as soon as it gets to 1st the grind and slow speed. I was able to get it home very slowly but now it wont go forward or reverse. And when i turn car on and in park it makes grinding and loose metal noise.
    1. Can i get the tranny from a 95 jaguar xj6 (4hp24), switch the bell housing and rear output shaft parts. Will it work? i feel this would be my cheapest and fastest option.
    2. take tranny out and completely take it apart. Order rebuild kit around $300 to rebuild it completely? but i am afraid it is totally broken inside and will end up costing much more to fix it.
    3. switch over to a 6-speed manual. I found a Getrag 420g for $400. I know i will need the pedals, master cylinder for the clutch, gear lever. What else wlll i need and can i get those parts from a 7 series or 540?
    4. I was able to buy a rough looking 1995 bmw 750il M73 V12 with a Getrag 5hp30 transmission. But i can't seem to find anything about being able to swap the tranny into my 850
    Any advice and direction would be greatly appreciated.
    Thanks guys.
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    1. NO
    2. Will cost way more than that. Way more
    3. Not that easy, the 420g needs an adapter plate and blessings from a 3 eyed wizard - at the least
    4. Again, NO
    Your options are #2 if you really think you can pull it off... but be forewarned, it is way more involved than you think and you'll spend a lot
    OR...
    Buy a used one and hope for the best
    OR
    buy a completely re manufactured and upgraded transmission with a 3yr warranty from these guys... I searched the country for a re manufacturer (not a rebuilder) when the 4hp24 went bad in the Dinan 750TT... this is THE place.
    www.peius.com
    Herman "The German" has been doing this for 30yrs, and they have like 80,000 transmissions in the warehouse. Nobody else wants to spend any time on the old 4HP24's anymore.
    Oh, and have somebody with a shop order it, you'll save like 20%
    '91 850i 6sp (mint) (sold)
    Sunny Cali,
    6.5 second 69 Camaro
    Which Trans did you purchase as a upgrade, Tia!
    Indianapolis, IN
    93 850Ci, 09 Caddy SRX
    Quote Originally Posted by cartoonz View Post
    www.peius.com
    Thanks for the info!
    1993 850Ci.....18 years & 165,000 miles and counting!
    The OC, CA
    95 840Ci
    Ron are you needing one as well?
    Current
    95 e31 840 Ci (Auto) Orient Blue 61k
    11 e90 328i Space Gray
    18 F15 X5 35i XDrive White
    Past
    00 e38 740 i (Auto) Titanium Silver
    94 e31 840 Ci (6 speed conv.) Avus Blau (This car was Awesome!)
    03 e46 325 Ci (Auto) Jet Black
    91 e31 850i (Auto) Diamond Black, Yes, two!
    00 e39 528i (Auto) Jet Black
    92 e36 325i (Auto) Laguna Green
    Indianapolis, IN
    Quote Originally Posted by IJustDrive View Post
    Nope...knock on wood. Just good to know where to buy.
    Sep 2008
    Santa Barbara
    Quote Originally Posted by 8eights View Post
    The 4HP24 has to be The same flavor as the original, meaning the coding tag on the transmission dictates the choice. Every transmission these guys do includes any/all tsb's, improved parts, etc. - all NEW.
    Sunny Cali,
    Cool, Thanks!
    Jul 2016
    Chicago, Illinois
    are slow
    Manual swap can be done with an adapter plate for the V8 420G, on ebay for $300, all clutch bits can come from an E34 of any flavor.
    Indianapolis, IN
    Quote Originally Posted by XAlt View Post
    For the M70?
    Jul 2016
    Chicago, Illinois
    are slow
    Quote Originally Posted by TedBobo View Post
    For the M70?
    Yes. Once the adapter is on it's like swapping a 560G. Shifts like a truck and cold second gear is cranky on 90% of them but they're fun to shift.
    https://www.bimmerforums.com/forum/s...swap-confirmed
    I've got a 5-speed from the V8 530i lying around, that's what I'm planning to use once I buy back "my" E32.
    Orange County, CA
    840Ci|725tds|Alpina B7
    How committed are you to this car? It looks like it has quite a list but I would just have it rebuilt professionally. I had the transmission in my Mercedes rebuilt for $2200 and it drives like new with a 2-year warranty. It only took a few days.
  1. hey guys so i need help with coilovers and bodykit for my 335i sedan!!!!!
    By dbgmlw in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 01-16-2011, 09:42 PM
  2. Help with choice and size for my e36
    By smithw3 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 02-02-2010, 09:21 AM
  3. Need help with Rims and Tires for a 2003 325i
    By daveyd in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 01-30-2007, 04:28 PM
  4. Replies: 0
    Last Post: 08-02-2001, 06:53 PM
