Results 1 to 7 of 7
Thread: Really bad Idle then dies attempts to start then no start
    Feb 2013
    Sarasota, Fl
    95 840CI 91 850I
    Yesterday after mid day start it really had a bad idle 1991 850i Auto. Then sputtered and died. A weak attempt at starting then it would turn over then nothing.
    Turns over fine but almost acts like it is out of gas.
    No check engine light no fault codes just turns over but no start.
    Go out this morning and it starts right up and idles fine. Drive it all day no problem.
    It was not out of gas as I did not put any gas in it for about 20 miles.
    I checked a couple of things but did nothing to it. And last thing I tried to do was start it without luck last night first thing this morning tried to start it and varoooom and nice steady idle.
    Any thoughts?
    BMW CCA #500359 E31 Chapter.
    Dec 2013
    Chicagoland area
    EXOTICS
    Perform a stomp test:
    1) Turn ignition to Run (not start)
    2) Wait for the EML light to go out.. <1 sec
    Then.. Do this 5 times (In less than 5 seconds):
    3) Press the accelerator all the way to the kick down button for about 1/4 second and release
    If you did it right, CEL will blink once, then blink out your code(s). After the code(s) it will pause and repeat the codes.
    Even if you have no codes, it should still blink out 1 4 4 4 . If you can't get it, turn the key back off for a few seconds and try again.
    Then...
    Shut everything off, and repeat the test, but press it 6 times to read codes out of the second DME.
    All codes originating from DME #2 should start with 2 flashes
    Good Luck!
    Feb 2013
    Sarasota, Fl
    95 840CI 91 850I
    Have a code reader and there are no codes.
    Sunny Cali,
    6.5 second 69 Camaro
    Wiggle some wires while it's running to try to reveal the issue, Maybe something is loose or even a hidden fuse, They are intermittent at times.
    Feb 2013
    Sarasota, Fl
    95 840CI 91 850I
    Am I right in believing that when the fuses in the trunk fail and when they fail the starter will not crank vs starter will crank but no start?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    There are two 'fuseible links' that are connected to the right-hand battery, one in a sleeve the other in a plastic assembly. These fail in mysterious ways and the only sure way to rule them out is to replace them.
    http://www.meeknet.co.uk/e31/Timms_B...use_Finder.htm
    My BMW Repair YouTube Channel
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by 2001740il View Post
    Car will still crank but no fire if one of those fails. Look up my recent thread on random no start.
  1. Starts...then dies 3 to 4 times then runs perfectly
    By MugenK20a in forum 1995 - 2001 (E38)
    Last Post: 02-03-2017, 01:23 PM
  2. e90 330xi drove great, died while driving, cranks, but no start...
    By wbwhiteboy04 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 11-08-2014, 04:56 PM
  3. M5 guys: really bad idle after leaving the battery disconnected?
    By MC Hammered in forum 1988 - 1996 (E34)
    Last Post: 09-28-2011, 11:13 PM
  4. When idling the RPMs drop to 450 then goes back to normal???
    By Ronnaferd in forum 1991 - 1999 (E36)
    Last Post: 03-25-2010, 05:56 PM
  5. After head gasket replacement back to a crank no start
    By shadyduk1979 in forum 1975 - 1983 (E21)
    Last Post: 09-28-2008, 09:32 PM
