Results 1 to 13 of 13
Thread: Conversion to Evans Waterless Coolant
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Folks,
    I have just bought a 2001 E38, quite excited about it! Thinking to convert it to Evans waterless coolant. Have noticed that previous owner had lot of issues with cooling system (from repair bils).
    Since I have never done such I've asked an Evans authorized shop for price and they quoted $1,100 for it (everything included).
    Isnt that extremely high? Curious to know what is normal range for the work.
    Thanks a lot!
    George
    Jul 2016
    Chicago, Illinois
    are slow
    88C stat and nothing else
    Jan 2006
    Ft. Lauderdale, FL
    98 740il, 00 540i,04 ZHP
    Yes that is crazy expensive.
    The 88*C t-stat is all you need. I actually used an OEM t-stat and had it recalibrated by a firm in TX. My car runs at ~92-104*C now depending on driving conditions. The upper radiator hose isn't nearly as rock hard as it used to be, and I regularly see 105-110*F on my dash with A/C blasting in the FL heat here. The best part is it still has the heating element in the thermostat, so the DME can control opening or closing it and doesn't throw a code.
    Apr 2006
    N Miami FL
    00 E38 750IL 92 E31 850
    lower Tstat and stock replacement coolant will not reduce system pressure......Evans will..
    92 Dinan Stage III 850 Twin Turbo (1 of 4)
    625 Hp on 93 pump gas @ 14 psi 660 ft lbs torque
    Jul 2016
    Chicago, Illinois
    are slow
    Quote Originally Posted by pumpedTSI View Post
    Operating temperature is why you need a colder stat....
    Jun 2013
    NJ
    e36 M3/4/5, 08 M5 6sp
    bro, DIY....it's not that hard! buy yourself 4 gallons of Evans. do your normal cooling system refresh, refill with Evans, bleed properly, check after a few days, top off as needed. Soon whatever water was left in the system will have evaporated and you'll be good to go!
    Apr 2006
    N Miami FL
    Quote Originally Posted by XAlt View Post
    Original post was conversion to Evans not the purpose of a colder stat.....the biggest advantage is no system pressure otherwise go with the stat/coolant and save the $$$...
    Jul 2016
    Chicago, Illinois
    are slow
    Otherwise you're risking running at 120C+ without the colder stat.
    Hot liquid damages gaskets.
    tmaxx445's Avatar
    tmaxx445 is offline E38 6 Speed Club Member! BMW CCA Member
    Dec 2010
    Greensboro, NC
    '05 M3, '03 X5, '01 740i
    There is no way around thermal expansion; the system will still be pressurized.
    2001 740i / S62 Swap / 6 Speed Swap / Titanium Silver Metallic / Grey Montana Leather / M Sport / Convenience Pkg / Heated Seats / PDC / MKIV Navigation / DSP / Bluetooth TCU / Dice Mediabridge / Vavona Trim / Illuminated ZHP Shift Knob / Short Shifter / Cat Delete / SAI Delete / Euro Tune / Koni Singles / H&R II Springs / Custom 3.15 25% Limited Slip Diff / Staggered OE M Parallels / 275 & 245 Firehawks / Euro City Lights / Celis Tail Lights / SunTek 70% CXP Tint
    2005 M3 Coupe
    / 6 Speed / Silver Gray Metallic / Black Nappa Leather / Premium Pkg / Cold Weather Pkg / Bi Xenons / Adjustable Bolsters / MKIV Navigation / Harman Kardon / Bluetooth / Sirius XM / Aux In / Carbon Trim / ZHP Shift Knob / Short Shifter / StreamLine Intake / SS Headers / AR20 Resonator / Exhaust Bypass Valve / P0lar Tune / Koni Yellows / Eibach Springs / Staggered OE CSLs / 275 & 245 595 Evos / Angel Eyes / CF CSL Splitters / SunTek 38% Carbon Tint
    2003 4.6is X5 / Stock /
    Denver Suburbs
    2001 750iL Sport
    $1,100?! For what, exactly?
    I've had Evans (the same batch) in my car for probably 5 years now. I love it. If I open the cap there's a small hiss and that's it.
    Buck - 2001 750iL
    3.15 Sport Rear Differential - M-Sport Steering Wheel - Bi-Xenon Headlights
    B&G Lowering Springs - M-Sport Seats - 15mm Spacers - Muffler Delete
    Jul 2016
    Chicago, Illinois
    are slow
    Quote Originally Posted by board57796 View Post
    What's your operating temp with the M73N?
    Denver Suburbs
    2001 750iL Sport
    108-112C usually. 112 if I'm idling for a long time in the heat.
    Buck - 2001 750iL
    Jan 2006
    Ft. Lauderdale, FL
    Running the engine at a lower temperature will reduce pressure. And significantly. The reason why the E38 has to run at 30 psi is because of the operating temp of the engine being well above the BP of water. Even though the 50/50 mix has a higher BP than water, it's not by much, so the system has to be pressurized to prevent boil over. Dropping operating temp 10-20 degrees C, significantly reduces the pressure needed to prevent boil over. I can squeeze my upper radiator hose when hot, whereas before it was hard as a rock. This also doesn't even mention the benefits to everything else from running a lower temperature.
    Not discouraging using Evans...the pressure will be next to zero with that stuff. It's just expensive, a hassle to convert to, and you can't top it off or anything if you're on the road and develop a leak. I also do not think the heat transfer is as good as water. Nothing has the specific heat capacity of water.
  1. Evans Waterless Coolant swap
    By davisenvy in forum 1996 - 2003 (E39)
    Last Post: 03-18-2016, 05:42 AM
  2. Evans Waterless Coolant
    By 1SGDHORN in forum 1976 - 1989 (E24)
    Last Post: 08-25-2015, 10:21 AM
  3. Evans Waterless Coolant
    By nickbaluyut in forum 8 Series (E31)
    Last Post: 09-14-2013, 11:59 PM
  4. Evans waterless coolant
    By gorillajin in forum 1996 - 2003 (E39)
    Last Post: 06-05-2012, 04:58 PM
  5. Waterless coolant... Evans NPG+ ?
    By Carzzi in forum 1992 - 1999 M3 (E36)
    Last Post: 04-05-2006, 11:59 AM
