E36 fuel system questions/issues with my LS1 swap
I have a 1997 M3, LS1/T56, that I'm trying to diagnose a fuel system issue with. The car is set up with a Walbro 255 in tank to a C5 Corvette fuel filter/regulator in the BMW filter location (set to 58 psi), then a single line to the engine. I have excess fuel pressure at the rail (70-78 psi) which I believe is causing running issues, after going from an Aeromotive Stealth 340 to the Walbro 255, and swapping out the regulator/filter with another new unit. I have the BMW evap purge hooked to the LS1 set up on the intake manifold, and this system is coded to function like it should with the LS1 computer. The car seems to idle fine but will stumble and die after a few minutes of driving, and smells like it's running rich. The plugs show signs of running rich as well.
I did some research and some people stated that high fuel pressure could be due to a blockage or restriction in the return. I pulled the return line off the regulator/filter, and blew a quick blast of compressed air through it. When I pulled it off, I had a trickle of fuel coming from the tank. After blowing the air through it to the tank, I had a steady flow of fuel coming from the tank to where the return line meets the regulator, which does not seem correct. My understanding is that that the OBD2 fuel tanks have an internal siphon, and the return line sits at the top of the tank on the passenger side. My testing seems to show that there would be fuel flowing backwards from the return, which may be a cause of excess pressure.
I had the tank out to do some chassis welding- is it possible to hook up the return line incorrectly? Is the pressure flowing backwards out of the return normal? Nothing seemed to indicate a problem when I put this all back together.
Instergrams: @davemakepictar
