Results 1 to 13 of 13
Thread: No start issue
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    No start issue
    Was changing trans fluid today on my 92 850, had all fours off the ground, when done I lowered her and went to start and nothing. She ran fine before lifting her.
    I hear clicking from the throttle bodies but no spark...no nothing. I disconnected the batteries thinking I maybe triggered some safety switch but no cigar.
    Any help would be much appreciated.
    Thanks.
    Aug 2015
    Oconomowoc, Wisconsin
    01 750il, E38/9 Parts
    Maybe disconnect battery again, turn the key to start for 30 seconds to drain all caps, and try again?
    Sent from my Nexus 6P using Tapatalk
    --- 750il Maintenance/Restoration Thread --- E38/9 Parts Cars --- YouTube Channel ---
    Woodland Hills, CA
    Disco II 850i MERs 750il
    The answer is always fusible link.
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Quote Originally Posted by bruinbro View Post
    Just checked fusible links and seem ok to me... see pic.
    Checked the coils and nothing irregular that I can see.
    Any other ideas?
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Quote Originally Posted by ColtonBH View Post
    Tried that. No luck.
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    You got to remove the plastic wrap. I had no start issue which was cured by replacing both of the links with some 80Amp ANL fuses. I could not see visible cracks but did see oxidation.
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    K. Will try that first.
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Installed fusible links and still didn't start.
    When I turn the key I just get a loud single click from the starter. Should I assume the starter has gone bad or could it be coils?
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by nrp22101 View Post
    So it just clicks and does not crank? You need to check voltage at the starter relay. It may be the starter.
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Ya, no crank. Unfortunately replacing the starter is above my pay grade. Any ideas how much i should expect to shell out for this?
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    Uhh... batteries bad?
    '91 850i 6sp (mint) (sold)
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Nope batteries are new and all lights, radio, et. fire up. Pretty sure it's the starter.
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Problem solved. Fires right up. New starter...part $170, labor $400.
  1. Odd 540i no start issue: not battery or starter related
    By kmoy2002 in forum 1996 - 2003 (E39)
    Last Post: 08-25-2009, 12:48 AM
  2. Interesting Take on the No-Start Issue
    By CoryUT in forum 1991 - 1999 (E36)
    Last Post: 12-12-2007, 10:58 PM
  3. no start issue..........
    By lil red coupe in forum 1983 - 1991 (E30)
    Last Post: 10-01-2006, 09:04 PM
  4. HELP:No start issues after head gasket/drive belt replacement
    By jessepro in forum 1983 - 1991 (E30)
    Last Post: 08-06-2006, 12:53 PM
  5. No start issue
    By Jeff48 in forum 1991 - 1999 (E36)
    Last Post: 04-26-2006, 08:48 PM
