Results 1 to 10 of 10
Thread: Weird P0021 Issue
    Jun 2016
    Wisconsin
    2001 740I M Sport
    Weird P0021 Issue
    Every morning I start the car, all is good. I drive for 2 minutes to the gym and workout for an hour. I start the car and I get a P0021 code. I clear the code with my scanner and the code is gone for the rest of the day. It does this everyday, same sequence. Does this mean the Vanos seals are bad, bad solenoid, or CPS?
    Jun 2016
    Wisconsin
    2001 740I M Sport
    Anyone?
    Jul 2016
    Chicago, Illinois
    are slow
    Chain guides starting to go
    Jun 2016
    Wisconsin
    2001 740I M Sport
    Oh yeah? I bought the motor from a guy that supposedly did this already. I think he is a member on this forum. Time to buy some timing tools and rebuilt vanos units.
    Feb 2009
    KC North, MO, USA
    1996 740iL
    That one is not always the guides. Seems like that code often pops up after the guides are done because it was not timed properly. You also swap the two cam sensors to see if the code changes. This will at least eliminate the sensor.
    Jun 2016
    Wisconsin
    2001 740I M Sport
    I'll try that tomorrow. For some reason I thought they were different lengths.
    Kansas City, MO
    2x01 750, 01 740
    As Chuck said, this code seems to usually come from the timing being off after doing the guides.
    Takes a few drive cycles to turn on the light for it which is why you only see it once a day.
    See my E38 parts for sale on eBay: click here!
    PM me here for a 5% discount on any of them!
    Bonita Springs, FL
    01 740i, 09 X5, 12 335i
    Quote Originally Posted by psjr View Post
    +1 Clear code, start engine and the code will not reappear until you shut the car off and start the next time. Sounds like the driver side timing may be off, or the trigger wheel is just slightly off.
    If you can get the crank to TDC, then you should be able to check the trigger wheel by removing the access near the cam shaft sensor and inserting the appropriate size drill bit directly into the alignment hole in the trigger wheel. See circle in pic
    2001 740i Sport - Anthracite Metallic, Gray Interior, 750 Porn Lights, 750 Seat Backs, Hoen Xenon-match Fogs, Crossed drilled, slotted rotors, LED Interior Swap.
    Jun 2016
    Wisconsin
    2001 740I M Sport
    Awesome. I'll do that and check back. My Vanos units are kinda noisey so I may have to do something about them. Dr. Vanos possibly?
    Jul 2016
    Chicago, Illinois
    are slow
    Quote Originally Posted by Cosmic E38 View Post
    Besian Systems, install guide on their site.
    The noise doesn't affect performance
  1. Weird Clutch Issue...
    By NotUrAvgM in forum 1975 - 1983 (E21)
    Last Post: 01-21-2005, 11:35 PM
  2. Weird HID issue.. help!!
    By infocalypse in forum 1992 - 1999 M3 (E36)
    Last Post: 12-30-2004, 05:20 PM
  3. Lower the coupe and now I've got a weird camber issue.
    By Shaun G in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 12-28-2004, 01:25 AM
  4. Weird Speaker issue
    By ///BHRpowered in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-02-2003, 08:37 PM
  5. weird alignment issues with KMACs
    By BJO in forum 1992 - 1999 M3 (E36)
    Last Post: 11-03-2002, 09:02 PM
