Results 1 to 6 of 6
Thread: Steering wheel vibration rattle at idle
    tvjake2's Avatar
    tvjake2 is offline SoCalEights - CA BMW CCA Member
    Oct 2012
    Glendale, CA
    '97 840Ci, 1980 308
    I've developed a very small vibration in the steering wheel (something like the feeling of an electric toothbrush vibration) when the car is at a stop, in gear and particularly with the A/C running. There is also a rattling sound that seems to be coming from under the dash during the vibration but I think it's actually in the engine bay. I'm guessing it's a problem in the hydraulics in the steering system...low pressure issue? Pump? Clogged hoses?
    Any ideas?
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by tvjake2 View Post
    Any ideas?
    What about the engine mounts?
    tvjake2's Avatar
    Oct 2012
    Glendale, CA
    '97 840Ci, 1980 308
    Quote Originally Posted by dragon850 View Post
    Just replaced engine mounts and trans mounts. It was doing this before that.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    What is the RPM at idle when this problem occurs? Below a certain RPM you will feel each pulse of the PS pump, especially if it is under load.
    My BMW Repair YouTube Channel
    tvjake2's Avatar
    Oct 2012
    Glendale, CA
    '97 840Ci, 1980 308
    Filed under the "You won't believe this one" category
    Thanks, Tim. I had the same thought and tried to determine if rpm was the culprit.
    The weird thing was when I moved the steering wheel 5 degrees to the right or the left the vibration and noise stopped. There were no leaks but I checked all the fittings for loose connections. Nothing. I started thinking that I had some issues with the power steering pump not supplying enough pressure. I have no equipment to test the pressure so I took the car to AVUS Autosports in Glendale, CA. They took me in right away without appointment (nice).
    Well, I was partially correct...it was in the power steering system, just not what I expected.
    When AVUS called back (within an hour) the first question they asked me was, "Who polished your power steering hose?" I thought that was an odd question but I said that I did when cleaning cosmoline off the engine compartment. I cleaned the cosmoline off the ps aluminum lines and then polished with Nevr Dull, the same stuff used in the Navy to polish everything that isn't painted grey. Turns out I had slightly distorted the hose, that seemingly happened when I polished the line, and when pushed back (an 1/8") into line the vibration and noise stopped. Amazing.
    I'll continue cleaning and polishing but with a more careful approach.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    How strange!
  1. Steering Wheel Vibration at 60
    By ezbmr in forum 1996 - 2003 (E39)
    Last Post: 01-26-2012, 12:05 AM
  2. Idle Steering Wheel Vibrations
    By Porfeo in forum 1991 - 1999 (E36)
    Last Post: 08-21-2009, 07:28 AM
  3. Steering wheel vibration at 60~mph (not tire balance)
    By rebs in forum 1992 - 1999 M3 (E36)
    Last Post: 06-13-2009, 02:39 AM
  4. Replies: 7
    Last Post: 10-06-2008, 11:35 PM
  5. Steering Wheel Vibration at Idle
    By E36M3Ranger in forum 1992 - 1999 M3 (E36)
    Last Post: 04-01-2003, 10:04 AM
