Results 1 to 2 of 2
Thread: Tricky Unlock of a 2004 BMW X3 PLEASE HELP
    Aug 2017
    2004 BMW X3
    So a few years ago, around 3 or 4 I was stupid and called AAA to unlock my BMW X3.. they ended up breaking the manual door lock. So for years I haven't been able to unlock the door manually and have had to rely solely on the key. Now for the past two years I've had my car in Texas and when I go home the battery always ends up dying, but the key still works and unlocks the door electronically when I get back. Now this last month I have been in Indonesia on an internship came back and my battery is dead (as usual), but this time door wont unlock and I cant use the key hole to get in. From my perspective if there's a way to pop the hood from the outside I can charge the battery and unlock the car. Some important things to consider: this has never happened before and for the first time I had my friend every couple weeks or so come by and warm up the car for 15-20 min so it wouldn't die, he told me it started up fine 4 days ago. Please help.
    warwick RI
    E30/E32/F25
    Jack the car up take the belly pan off (8mm). On the drivers side look for the starter there is a large power cable on there. Attach a jumper to that and then hit unlock. I usually use a little "alligator clip jumper" if It's tight. You don't need much power to unlock the car as you already obviously know
    You should be able to connect a ground anywhere to the body where there is bare metal. Even the outter casing of the starter. Just don't get zapped if you do that as your going to have a power there already
    Me E30 87/ 325i + F25 12/ M-Sport + E32 94/ 740i
    G/F’s E34 92/ 525iT + F48 18/ X1
  1. Tricky Unlock of a 2004 BMW X3 PLEASE HELP
    By hamzilla95 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-16-2017, 09:42 PM
  2. New owner of a 2004 BMW X3 3.0
    By RetrogradeJam in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 04-12-2017, 10:49 PM
  3. Feeler: 2004 BMW X3 OEM Wheels, 17", Set of 4
    By lickwid in forum Wheels and Tires
    Last Post: 01-20-2011, 12:44 PM
  4. A Big Favor I Need To Take Pics Of An Avus Blue Bmw M3!!!!!!!!! Please Help Me!!!
    By bmw m3 s50 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-18-2003, 05:26 PM
  5. Replies: 0
    Last Post: 10-17-2003, 02:53 PM
