Results 1 to 10 of 10
Thread: Replaced cluster on 525i and noticed improved perfomance...
    Mar 2016
    Spain
    e34 525i
    How is that possible?!
    My rpm gauge was reading like 400 rpms above of wha it should. Like my idle speed was 1100 indicated however the diagnostics computer read 700 rpms.
    Finally I ended up purchasing a used cluster really cheap. I replaced it and my surprise was that the car performed much better and it gained some torque around 4K rpm, where previously used to have some sort of dip in power. Just at the point where the vanos comes to play. It had a really noticeable dip from 4500 to 5500 or so. I could clearly notice it if I went WOT for the first time from down low rpms all the way up to the rev limiter. First time doing this after driving normal, and you could clearly feel it had some sort of torque dip around that rpms...
    And well, just swapped the clusters and a few kms later that thing is completely gone!
    Does that make any sense!?
    I read somewhere that the VSS signal on the speedo has something to do with how the VANOS operates... and as long as there is some sort of VSS signal, be it right or wrong, the DME does its stuff...
    My speed cluster was working properly... I think so...
    What if I try to run the car without the cluster connected? Would it work the same? Does the DME need some sort of feedback coming from the clusters?
    NW suburban Chicago
    hiss by my window
    The DME does use vehicle speed and the vehicle speed IS processed through the cluster so....
    Who'd have thunk it though?
    One for the memory banks.
    Oct 2014
    Latvia
    1988 BMW e34 525i
    Was the battery disconnected while changing clusters? That might have resetted the DME. Or what the guy above said...
    Sent from my Samshit SM-G900F using Tapatalk
    Mar 2016
    Spain
    e34 525i
    It was somehow weird cause I wasnt expecting any kind of improvement... but it did..
    I had some issues when driving below 2K rpms, like sometimes it missfired and run like crap when too low engine speed and 3rd gear or so... it didnt when 1st and 2nd gear. 4th gear was even worse. 5th better not try.
    And then it was that dip in power when above 4K.
    All of that is gone.
    Awesome, isnt it? I wasnt expecting that...
    Jan 2013
    Sarasota, FL
    2x 93' E34T + 95' 750iL
    Given that I'm sure that the car runs without a cluster installed, I'm pretty sure you're just experiencing a placebo effect.
    Mar 2016
    Spain
    e34 525i
    Quote Originally Posted by Creesic View Post
    That would be true if I was expecting it, but I wasnt!
    Some members of other forums told me that the e34 tds , for instance, has poor performance and hesitation while accelerating without the cluster connected. Maybe this is true for the e34 m50 aswell. Maybe you can run a while without it connected and no symptoms I dont know... for instance I drove the car without the TPS connected for 10 miles or so and didnt notice it...
    To me, it clearly showed some improved noticeable performance... which is still right now... in fact, a friend of mine has just told me a few minutes ago he did notice it aswell... but there is the chance it is some sort of placebo effect who knows...
    NW suburban Chicago
    hiss by my window
    Nope, entirely plausible.
    The engine management needs all of the inputs at correct values for best performance. When wrong it will either respond incorrectly or substitute fixed values not optimal.
    The speed signal is processed through the cluster, a deviated signal could cause running issues.
    Jan 2013
    Sarasota, FL
    Quote Originally Posted by ross1 View Post
    Just found that out looking at diagrams. Makes sense now.
    Jun 2017
    Chicago
    1995 540i & 1996 328i
    Where are you looking? In the BMW electrical diagnostic manual? If so what index number is it?
    Jan 2013
    Sarasota, FL
    Quote Originally Posted by Billyj View Post
    I'm doing some megasquirt wiring, and it appears that speed and tacho data is called from the ECU to the cluster in some way, and then spat back out.
  1. Replaced cabin air filter and noticed unplugged wires -- help?
    By Rose City in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-29-2016, 08:31 AM
  2. Replies: 6
    Last Post: 08-06-2015, 05:43 PM
  3. Z3- Removing/Replacing boot on shift and e brake
    By biomanghs in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-25-2012, 10:34 PM
  4. Replace valves on s50 and rev up to 8000?
    By mindstorm00 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-09-2010, 12:50 AM
  5. Replacing Cluster on Newer BMWs
    By MBENZF1 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-04-2006, 02:51 PM
