Results 1 to 21 of 21
Thread: Bigger Exhaust ? for 550+ whp
    EGYPT
    E30
    I ve searched alot through the internet , but I cant find a solid answer
    I ve an e30 M50b30 (m54b30 internals ) with top mount Holset 6764 exh16 , I m shooting for 550-650 whp (I hope )on 95 octane + water Methanol
    my turbine flange is 2.5", and I used an adapter 2.5 to 3" down pipe , to a whole 3" exhaust with Mitsubishi evo 3" resonator to an HKS hi power muffler replica , I only have 4 90 degree bends from the turbo to the end of the exhaust
    would this exhaust cause any restriction ?
    would bigger down pipe (only) increase spool ? ( was planning to upgrade to 4" but my tuner tells me that I ll lose some torque and suggest 3.5")
    If I go bigger ( do I need ? plan is to have power available on lowest boost , 18 -19 psi Max ) ,
    I hear two theories ,
    1- Bigger downpipe is better into smaller exhaust as of 4" downpipe to 3.5 exhaust ( based on that, for a turbo engine better exhaust is no exhaust , and gases slow down at the end of the exhaust )
    or
    2- 3.5 " downpipe to a bigger 4" exhaust ?
    I ve been searching for 3 days and only getting mixed reviews
    N.B :in my country the 3.5 pipes are rare and though more expensive
    Manchester, N.H.
    96 332IS 6466 turbo
    Why would your tuner tell you that there would be a TQ loss ?
    Turbos need to flow. Its not a SCer.
    For 600 whp or even 750 3.5" is more then sufficient. Probably no gains from 3.5 to 4. But certainly a gain from 3 - 3.5.
    Go 3.5 for clearance. I ran a full 4" for a few years, sucked for clearance. Recently tigged up a 3.5 and couldn't be happier with it. No more scrapping
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    Mar 2012
    Renton, Wa
    98 m3
    You should leave whatever tuner that is... yesterday.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    Manchester, N.H.
    96 332IS 6466 turbo
    Another note, its more important to have a larger exhaust than downpipe.
    Or equal.
    3" downpipe into 3.5 exhaust is better than 3.5 downpipe into 3" exhaust.
    Reasons velocity, and as the exhaust cools it expands. Kinda like how its kosher to have 2.5 hot side then 3" cold.
    For 600 HP I would do either 3" downpipe and 3.5 exhaust or 3.5 the whole way.
    1996 332IS
    Built 3.2
    Toronto, Canada
    E36 Turbo
    Or equal.
    It's the other way around really... Larger DP is more important... hot gases expand
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by NOTORIOUS VR View Post
    Not sure about that.
    Iirc tests have shown how I wrote it. Maybe I'm wrong but velocity will push and then expand as it cools. Like charge piping.
    1996 332IS
    Built 3.2
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Gas expands as it heats up. There could be other forces at play in a turbo exhaust that make it work with a big DP and small rear, but I would go big on both. The Super Street article on the turbo showed a 3.5 rear added power at the 500+ rwhp level over a 3.0 exhaust on a Toyota Supra. They then added a 3.5 DP and picked up more power. They never tested the 3.5 DP with the 3.0 rear so we don't know how that combination would have fared.
    http://www.superstreetonline.com/how...ust-test-tech/
    Charge piping might be different. The added velocity of the air in the smaller hotside pipe might be helping get the air through the intercooler.
    Toronto, Canada
    E36 Turbo
    At the end of the day, on a turbo car you're working with a pressure differential to drive the turbine... a bigger pipe after the turbine is always going to be better for a turbo car.
    EGYPT
    E30
    This is what I have been through for past days 😂😂😂 Mixed reviews
    I came across the superstreet article
    They picked up to 100 whp from going full 3.5 exhaust
    Another trusted tuner from sweden showed me 4" dp into 3" exhaust on holset hx40 making 685 whp on m52 with e85
    I m. Really confused
    Toronto, Canada
    E36 Turbo
    Quote Originally Posted by JOMARO View Post
    This is what I have been through for past days  Mixed reviews
    There isn't much to be confused about.
    Can you make 600+ on a 3", sure... Will you gain power by going bigger? Most likely.
    What it is all worth to you, only you can answer that.
    EGYPT
    E30
    I m settled on upgrading my exhaust , just cant choose wither a full 3.5" (DP+ Exh)
    or 4" DP with 3.5 "exhaust
    Apr 2006
    Minnesota eh?
    86 325es
    do whichever fits better.
    A house
    '86 325e, '14 VW EPA
    Toronto, Canada
    E36 Turbo
    option two would by my choice if you have the room and the $$... option one is going to be more than sufficient for your power goals though.
    Frederick, MD
    '87 e30, '02 e39 Dinan
    Step one: Calculate the amount of Air flow is required through an engine to obtain said hp.
    Step 1.5: calculate density of hot gas
    Step Two: Given density and flow rate, you can calculate velocity of the gas through each diameter of pipe.
    Step three: Calculate the pressure drop from each diameter.
    Step Four: Choose the diameter that gives you the lowest respectable pressure drop. (at some point it will be minimal difference)
    Step five: Confirm diameter will fit.
    Step 5.5: Don't forget to confirm that your waste gate will be able to control your low boost levels. (larger exhaust now means more flow through it and less through waste gate meaning harder to control boost levels at lower levels)
    Step Six: Drink beer that was a lot of math
    Step seven: Ask euro to find his excel sheet for this bs
    Capital Driving Club Car # 102
    How to turbo your car:
    Step one. Install ecu and learn to tune and or have it tuned.
    Step two. Install injectors and retune.
    Step three. Install turbo parts and bits. get it running with out leaks. DO NOT DRIVE IT. Idling should be ok
    Step four. Retune car
    Step five enjoy
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Step 1: put the biggest mfer exhaust pipe you can fit on that hoe.
    Step 2: brapppppppp
    Step 3: stututututu
    Step 4: thank me
    Jul 2005
    California
    Bima
    5' of 3'' exhaust $180.
    hoorry shiitt!
    Vancouver, B.C., Canada
    '97 M3
    If I was going to go oval it would definitely be 4" oval tubing.
    EGYPT
    E30
    I went 3.5" for the downpipe and exhaust (just a straight pipe ,no mufflers no resonators ) will hit the dyno on Monday , and will see what numbers can we get
    Manchester, N.H.
    96 332IS 6466 turbo
    Results ?
    1996 332IS
    Built 3.2
    EGYPT
    E30
    650 whp -577 lb/ft on 1.5 bar 93 octane + water methanol
    I m more than satisfied :-) , will post dyno sheets soon
  1. Check out this brand-new SS Exhaust for $550.. worth it??
    By torquey in forum 1991 - 1999 (E36)
    Last Post: 09-30-2004, 02:37 PM
  2. SS DTM Exhaust for E36 M3 $550 obo
    By CSLBILL in forum BMW Parts For Sale
    Last Post: 03-06-2003, 01:57 PM
  3. SS DTM Exhaust for E36 M3 $550 obo
    Last Post: 02-27-2003, 05:50 PM
  4. Dinan exhaust for sale...
    By eurospec#19 in forum BMW Parts For Sale
    Last Post: 03-30-2001, 05:54 PM
  5. Anyone have a Dinan Exhaust for sale?
    By mpower4 in forum BMW Parts For Sale
    Last Post: 03-04-2001, 10:13 PM
