Results 1 to 20 of 20
Thread: E36 rear tires rub on bumps
    Jun 2017
    East norriton, PA
    1997 BMW 328 convert
    Group
    Just bought a 97 328 convert
    That has 17" rims from another BMW
    Not sure what , but they seem to push the tires out just past the body and the sidewalls
    Are getting destroyed on bumps.
    Can someone tell me how to fix or what year these wheels Are off of?
    If I can post a picture somehow?
    Jun 2017
    East norriton, PA
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    What is the tire size and the ET of the wheels?
    Here some info https://www.wheel-size.com/size/bmw/3-series/1997/
    Apr 2017
    United States
    95 540i,98 328i, 93 325i
    Looks like the wheel offset is too far. Did you check if there are spacers behind the rims? If you want to continue to run that setup you can roll the fenders. Can you give us a picture of the offset with the fender and wheel( a picture from the front or above the car showing how much the tire is sticking out)?
    I believe those are style 290s off of a Z4
    http://www.bmwstylewheels.com/bmw/290
    1998 318i m52 swap 3.38 lsd, 1995 540i/6 speed (SOLD), 1993 325i, 1999 328is m-sport, 1996 328i GT35
    Aug 2013
    1999 BMW M3 Coupe
    You need higher offset wheels so they tuck under the car and away from the fender lips, more negative camber, a higher ride height, or a combination of those.
    That said, that looks like a front and on an E36 you should have boatloads of room to the fender in front even with a low offset wheel. How wide are the wheels and tires, and are there any wheel spacers in there? On my M3 I could go from the stock 17x7.5 ET41 225/45 to a 17x9 ET30 (including spacer) 245/40 with no clearance issues and my car is lowered about an inch.
    Jun 2017
    East norriton, PA
    Its a rear wheel picture
    Front has plenty of room
    Tire is a 215 45 17
    I have to check for a spacer
    When I get home
    Oct 2003
    Seattle
    99 M3
    WOW!!! If you push down on the rear fender just above the taillight does the body bounce right back? Your shocks might be toast.
    Wheel offset appears to be the issue 7 1/2 wide 17 inch diameter E36 wheels are typically ET41, can go as low (or high) as ET35. I think you have ET27, not good.
    http://www.tsw.com/explore/what-is-wheel-offset.php
    Jan 2015
    AZ
    96 328i, 92 318i
    Yeah man, just judging your ride height you shocks are blown and your car is bouncing around like a jalope. You should not be rubbing like that. get some new shocks.
    Jun 2017
    East norriton, PA
    Ok
    So I push on the back corners of the car
    And get no movement at all
    Like it's stuck at that height.
    The front I can compress
    What's causing that?
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    Quote Originally Posted by Beer+Oversteer View Post
    This.
    The wheel is too wide and the offset is to low. More correctly, the combination of wide and offset puts the tires into the fender.
    Factory fitment for the E36 is a 7 or 7.5 inch wide rim, with an ET (offset) of 41. You have a width of 8, which is 13mm wider than stock, plus your offset is 12 mm less than factory fitment. Combined, you are pushing the tires outboard by a full inch, which is causing the rub. The tires you should have should be 225/45x17, but these would rub worse than the tires you have.
    You might be able to roll the fenders outboard a few millimeters so that the tires clear.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by JDStrickland View Post
    This.
    Factory fitment for the E36 is a 7 or 7.5 inch wide rim, with an ET (offset) of 41. The tires you should have should be 225/45x17, but these would rub worse than the tires you have.
    My M has factory fitted 8 1/8 ET41 wheels in rear with 245/40-17 tires and no rubbing. Front is (as stated) 225/45-17 on 7 1/2. E36 M and non-M body shape are all the same.
    Wheel offset is issue here.
    May 2009
    Greenville, SC USA
    e39 M5 e39 540i6 e83 e53
    Just roll your fenders. I run 18x9.5 ET25 with a 245/35 and don't rub. You probably just need a slight roll and problem fixed. Your spring/shock issue sounds normal for a stiffer setup.
    Jun 2017
    East norriton, PA
    Quote Originally Posted by Auto Parts Guy View Post
    How does one go about that?
    Oct 2003
    Seattle
    99 M3
    Eastwood has "The Roller" for cheap.
    http://www.eastwood.com/ew-fender-ro...SABEgJtQPD_BwE
    Or the old fashion way with a (wooden) baseball bat.
    May 2009
    Greenville, SC USA
    I bought a roller from either ebay or amazon but you may be able to get away with a wooden bat since you dont need much. the roller was worth it though..
    Aug 2017
    Chambersburg , PA
    1995 BMW 318i Built M50
    Okay , I'm a "stance" kid . So you're on stock suspension correct ? if so you most likely have blown shocks giving your spring too much play causing the wheel to shoot into the fender. the way to check . is to simply bounce the side of the car and it shouldn't bounce back up more than 3 times nor be easy to push down. Alternate way that costs no money is to roll the inner fender lip upward and in using a heat gun so you won't chip the paint & ****lightly tapping the metal in with a hammer*****(don't use a metal one) Or get some smaller width tires
    Jun 2017
    East norriton, PA
    I think I'll just go with the correct wheels
    Will the later year 3 series fit no problem?
    I see a lot of early 2000 wheels from 3 series for cheap
    Apr 2017
    United States
    Did you check to see if the wheels had spacers behind them?
    Jun 2017
    East norriton, PA
    Yea no spacers
    Sep 2012
    New Zealand
    2006/2007 E61 530 & 525
    Similar, but different. The bolts holes are in the wrong place. They look like a knock off. Style 290s will fit ok with the fender lips rolled. Ask me how I know
    1990 E34, 1989 E34, 1996 E36
  1. Rear tire rubbing issues on the passenger side. Bad bushing or ball joint??
    By natedilla in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-04-2009, 02:54 PM
  2. Eibach/Koni's causing tire rub on an E36
    By Shuasha in forum 1991 - 1999 (E36)
    Last Post: 08-06-2009, 02:53 PM
  3. Slight tire rub on rear shock..spacer's???
    By wastedincome in forum 1988 - 1996 (E34)
    Last Post: 02-16-2009, 11:26 PM
  4. e36 m3 rear tire fit on 17x8.5 et40 kosei K1s (no fender roll)
    By BMWing in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-28-2007, 07:25 PM
  5. E36 Rear Tire size on RKII rims?
    By dragonm3 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 02-20-2004, 09:47 PM
