What is the best injectors to buy? My friend was telling me about a "4 port" injector for more power. Does anyone have any thoughts on this? Thanks
The claim is they improve fuel atomization, which leads to a bit more torque thus more power and a bit higher MPG. They're also quieter, those EV1s are pretty noisy. EV 6 injection valves are designed to inject the fuel as efficiently as possible into the intake manifold runner to achieve a homogeneous distribution of fuel in air flow.
if you want 4-hole, you still need the same specs, and that is : Resistance [Ohm] 15,95 Ohm, Static flow rate at 3 bar, medium N-Heptane [g/min] 150g/min
easiest is you stay with your Bosch, Injection valve BOSCH 0 280 156 372 ,BMW 13641706176 because the AFR is fixed https://en.wikipedia.org/wiki/Air%E2%80%93fuel_ratio
If you want real more power, then you also have to change some other parts too, or replace among others the old style AFM against a Miller system with MAF, Chip etc https://www.millerperformancecars.co...-miller-detail
If I purchased this kit. Does it matter that my engine has no mods on it yet for the turbo kit i want to buy in the future? With it increase power and performance just adding it to a stock engine?
https://www.millerperformancecars.co...age-m30-detail
Second, by buying this am I buying things i will need anyway when truboing my engine. Thanks
I understand the kit from Miller is enough for a engine without any other mods, the kit includes everything. But if you want to turbo, then you need different things = Miller MAF OR Turbo equipment.
Understanding that truboing with be much different, I guess what I am asking is, is there any overlap in equipment I am buying with this kit? In this kit are their things that I will need to buy anyway when buying a trubo kit? Or is there no overlap of parts TCD turbo kit? Thanks
I assume nothing overlaps, the Miller MAF set is just for their MAF including the chip
Great Thanks Shogun
If you see it from viewpoint of cost, the Miller option is cheaper, also I am not sure if you find someone in the area where you live in the Philippines which could make all the installation work for a M30 Turbo set-up and make proper maintenance.
That is a point you have to consider too.
